6 inch rear drop?
im wanting to order the 6inch rear drop kit on early classic.
but the kit doesnt come with a c-notch. am i gonna need one? im not sire if i need one cuz i understand its a kit but i would think kits come with everything u need rite? oh and can i see some 6inch rear drop pics? |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: 6 inch rear drop?
I am using 6 inch drop springs from GMC Pauls in my 69' and I Do Not have a c-notch. I will eventually cause I will bag it.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 09-11-2009 at 10:31 AM. |
Nothing to see here.....
![]() Join Date: Jun 2007
depends. I'd think for sufficient axle travel, you'll more than likely need a "c" notch for a drop larger than 4".
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 09-11-2009 at 01:44 PM. |
myoldchevytruck can i see a pic of your truck since u have a stepside just like me?
i want too see how the rear looks! so should i get a cnotch then? |
i'll dig a pic from my photo bucket out for you. I'm gonna notch mine prolly after the holidays but thats only cause I'm gonna bag it
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
#6 | |
My truck has a six inch drop with springs and it still has few inches before it bottoms out....I dont have a notch and wont be doing one till I bag it if I ever...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
what drop do u got in the front?
Moderator
![]() Join Date: May 2007
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
TOTY 2006
![]() Join Date: Dec 1999
Same for my truck, 4/6 drop with no cnotch.
![]() Join Date: Nov 2006
6" drop and if i hit a even decient bump it hits the frame and forget hauling anything
I BELIEVE IN JOHN 3:16 |
#13 |
resident oilfield trash
NOtch it Mine is 7 inches and with out the notch the axel would be resting on the frame. Surely you want more than an inch of travel
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#14 |
u said ur rear is 7 in is ur truck bagged?
#16 |
I think it depends on the truck, a short bed is lighter so it compresses the springs less than a longbed, when I put 6'' drop springs in the back of my panel the axle was on the bumpstops so i c-notched it.
#17 |
i cant really see the drop pics its to dark!
well im going to be droping my short step and i understand how u said its lighter than a long bed! |
#18 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Why do you abbreviate stuff ? It's hard for everyone to read.
#19 |
when i install the c-notch do i have to cut into the frame?
#20 |
Moderator
Yup
#21 |
say i get 6inch coils and 1inch lowering block, would that make it a 7inch drop?
#22 |
Blaze-Air
yes 7in
#23 |
ok cool how does a 7inch drop look?
oh and how does the lowering block install? |
#24 |
Blaze-Air
The blocks go between the axle housing and control arm.
If you go with a 4in drop or greater, I would suggest a super track bar and the shock relocators. These are pretty much, Must Have items when properly dropping a truck. As the rear of the truck gets lower, the rear tends to shift to the side. The track bar will help to correct that issue. The stock shocks will lay too flat in the factory position, that's why you will need to relocate the shock mounts. There are many vendors that supply these items. I use ECE(Early Classic Enterprise)for most items. |
#25 |
The LuvShack Garage
Wheel and Tire choice makes a huge diffy. I got 20/22's on my
Blazer frame with a 5/7 drop and it doesn't look as low as it did when I had the 17's on it 2 weeks ago. (It's just rolling chassis)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
