Old 09-11-2009, 03:12 PM   #1
terrellautosports
New Member
terrellautosports's Avatar
Did a little windshield trim repair work.
i had some bad spots at the corner of the windshield when we took it out. you can see by pics it was pretty bad. had never done this before so i was kind of leary on how it was going to go. got both sides on first shot.
i had to make a backing plate like what was original for it all to work.
the first pick is of the one i did first, with out taking pics. wasn't thinking. the other pics is of what it did, without grinding. so i took pics of steps i took to finish. didnt take pics step by step but you should get the gist.
going to seam seal where it should be.
let me know what you think..
1968 SWB Project. Soon to Start Build Thread
terrellautosports is offline   Reply With Quote
Old 09-11-2009, 04:20 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Did a little windshield trim repair work.
Looking good. Keep us posted on progress.
What welder did you use?
68gmsee is offline   Reply With Quote
Old 09-11-2009, 05:25 PM   #3
terrellautosports
New Member
thanks. will keep up on posts. will probably make build thread a little later.
the welder is a lincoln nascar addition. works great.
