Pusher or puller fans?
I have a '79 1 ton with a 350. My fan shroud is broken and the mechanical fan is bent, so they need to go. I was planning on installing an electric "puller" fan on the back of the radiator as is normally done.
Then I noticed how much space I have between my grille and radiator. I don't have AC or an automatic trans, so all that's there is the radiator. Is there any particular reason why I shouldn't try to mount "pusher" type fans between the grille and radiator as opposed to behind the radiator? It already runs cold as it is, I think I need a new t-stat.... |
Re: Pusher or puller fans?
i don't think they push as much air..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
puller is the way to go. Be-cool makes a nice fan with a built in thermostat
In the Forgotten far North.
![]() Join Date: Jul 2007
I've always installed pusher fans between the grill & Rad and have had no problems at all with over heating in the past.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
BAD BOW-Silverado XST
