Old 09-12-2009, 03:18 PM   #1
bdmcgee
bdmcgee's Avatar
Wood bed install
The wood is all cut & drilled and ready to be finished before we install it. . . We were going with a marine grade varnish, but after seeing how beautiful the oak is, we're thinking about just going with clear urethane. Any and all thoughts, opinions, and/or experinces would be greatly appriciated.
Thanks guys!
bdmcgee is offline   Reply With Quote
Old 09-12-2009, 11:22 PM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Wood bed install
Clear urethane cracks after a few years. I've seen it too many times. After that you're stuck with it. Water gets in the cracks and turns the oak black which really looks nasty. the only thing you can do is to try to grind the whole mess off and start again. I used Watco teak oil then Man o' war spar varnish and steel wooled between each of 6 coats. It came out beautiful. I protect it with a tonneau cover and park under a carport because I don't believe there is any finish that will protect wood from direct weather. Just my .02
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-12-2009, 11:45 PM   #3
coloradosean2009
coloradosean2009's Avatar
I would use a natural oil with a little bit of pigment. Watco is a good choice. I prefer the golden oak color myself. After about 3 coats of that on all sides, the wood will be protected. Anything that builds a film, like poly or varnish will eventually fail. In Colorado the sun will make that happen in one season. When that happens, the wood will need to be sanded to remove the failing film coat. That will suck.
By not using a film finish, you will be able to "revitalize" the wood without sanding through a failing film. Seasonally you can reapply Watco to the boards. This will bring back the color that you had in the wood and protect it from the elements.
Unless your rig is going to sit in a garage most of its life, a simple oil finish is the only way to go.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 09-13-2009, 02:08 AM   #4
Green Machine
Green Machine's Avatar
I agree - since we didn't want to deal with a peeling finsh either, we used Penofin Marine oil finish. Not as pretty as varnish, but when it needs redone, we can powerwash it, maybe use a cleaner to brighten the wood, and mask off and reapply.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
