Old 09-12-2009, 03:36 PM   #1
ironhead342001
heat lever operation?
Does the heat lever in the switch assembly operate a valve behind the fire wall?
67 C50 dump truck
69 C10 LWB
70 C30
72 K5 Blazer
ironhead342001 is offline   Reply With Quote
Old 09-12-2009, 05:08 PM   #2
ironhead342001
Re: heat lever operation?
I tore it all apart and the cable runs from the lever to a bracket behind the fire wall. It doesn't move anything. WTF is the purpose of the cable?
67 C50 dump truck
69 C10 LWB
70 C30
72 K5 Blazer
Old 09-12-2009, 07:26 PM   #3
JimKshortstep4x4
The heat lever cable hooks to the temperature door which is on the outside of the firewall. The cable goes through a plastic plug to connect to the temperature door. If you pull the plug you can see the door and where the cable hooks up.
The heat lever positions the door from all air routed through the heater core or no air through the heater core. By controlling the amount of air flowing through the heater core the air temperature coming out of the heater can be controlled.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-12-2009, 07:28 PM   #4
ironhead342001
Please disregard this thread, the person who submitted it is a total dumba$$ and has figured out what a stuck flapper looks and acts like. Thank you for your time, Ironhead.
67 C50 dump truck
69 C10 LWB
70 C30
72 K5 Blazer
