Get this carb on this intake
I have a 1406 square bore Edelbrock Carb that I want to mount onto my stock 350 chevy truck. I installed an Edelbrock 2101 intake- the older model that looks like:
![]() Thanks, Ed |
Re: Get this carb on this intake
either one should seal
![]() NOS is like viagra. Impressive? Yes, but once you run out your left limp and inadequate. Racing in a Honda is like beating up a retarded kid, win or lose, you still look bad.... |
not should, will seal.
the divider is not neccessary and you are only talking about 1/64 of an inch gap. what you really need to look out for is if the carb butterflies will clear the divider on the intake. |
I don't think these pills work
if your intake is a spread bore like the one in the pic and the carb is a square bore you will need an adapter
SQUARE84 ![]() 90 SUBURBAN |
The flange on that manifold is universal. You put the studs in the correct holes and you use the gasket that matches the bottom of you carb. For the carb you want to use, an open square bore gasket will be fine.
1977 GMC Sierra Grande |
So, he doesn't need a square bore spreadbore adaptor? When I have done that swap I have always used one.
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
No adapter is needed. The manifold is universal as previously stated. Just put the studs in the right holes, drop on the gasket and carb. It will seal fine.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#8 | |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
