Old 09-13-2009, 03:00 PM   #1
71 c10 rat
Long box one piece drive shaft??
i have a 71 long box that i just swapped a 454 and TH400 into. i would like to take the truck to the drag strip on the weeks and i'm not so sure if the 2 piece drive shaft would hold up. what would i have to do to make a 1 piece drive shaft work?
71 c10 long bed 454/TH400
"chrome wont get you home"
71 c10 rat is offline   Reply With Quote
Old 09-13-2009, 03:32 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Long box one piece drive shaft??
a 2 piece is stronger than a one piece, and is able to maintain better driveline angles. Make sure it is in good working order and it'll be fine
Old 09-13-2009, 03:36 PM   #3
Puropedo
Your driveline will probably hold up, but your bearing carrier will not, specially if is not the OEM beariing carrier, I had a two piece driveline on my shortbed and replaced the carrier didnt even lasted 4 months, so I just had them made me a 1 piece driveline, now, for your long bed Ive never seen one with a 1 piece driveline, my suggestion would be to to get a heavy duty bearing carrier but they are pricey$$$. Good luck.
Puropedo is offline   Reply With Quote
Old 09-13-2009, 03:39 PM   #4
71 c10 rat
any suggestions on a place to buy a heavy duty carrier bearing for the 2 piece drive shaft?
Old 09-13-2009, 06:20 PM   #5
hayhauler71
hayhauler71's Avatar
I bought mine from Inland Empire Driveline best part i put on my truck. solid aluminum housing with polyurethane center
hayhauler71 is offline   Reply With Quote
Old 09-13-2009, 06:59 PM   #6
71 c10 rat
thanks for the all the help
Old 09-13-2009, 07:07 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Just curious...what did they charge you for it?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-13-2009, 07:23 PM   #8
john
member #16
john's Avatar
Heres a link.
http://www.iedls.com/bearings.html
john is offline   Reply With Quote
Old 09-13-2009, 07:35 PM   #9
hayhauler71
about $75.00 shipped
Old 09-13-2009, 07:38 PM   #10
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Originally Posted by Puropedo View Post
...for your long bed Ive never seen one with a 1 piece driveline...
If it wasn't for the fact that it's raining and my motor is out of my truck, I would put it up on a lift and take a picture of it for you.
I had a 1 piece drive shaft put in when I found out that would be the cheaper route when my carrier bearing and u-joints went bad.
It was just under $300.00 to have it made, and installed with new u-joints.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 09-13-2009, 07:46 PM   #11
Puropedo
Does your truck have the stock height? I would think most likely, or else you would have clearance problems with the center crossmember.
Old 09-14-2009, 04:07 PM   #12
toddtheodd
toddtheodd's Avatar
Dropped 2 inches all around.
No problems with clearance... though I haven't had it lifted up to change the tires yet... then again, I'll just make sure to insist that they lift it using the back axle.
IIOY???
Old 09-14-2009, 11:33 PM   #13
Naterman35
Well heres a question. did any long beds come from the factory with a one peice... If not will any other vehicles swap driveshafts?... Mine has a 1 peice and im really guessing it wasnt custom... but it could have been.
Naterman35 is offline   Reply With Quote
Old 09-14-2009, 11:44 PM   #14
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
All you need is a 3/4 ton drive line & bracket set up. The carrier bearing holds up fine. Launch after launch @ 3600 RPM. The standard center hung will break in seconds.
You don't need any thing fancy. My Truck scales out at 4013lbs with me in it.
So to launch @ a 1.65 60' time after time it's tried and true.
68 C-10 KID is offline   Reply With Quote
Old 09-14-2009, 11:54 PM   #15
Longhorn Man
no 67 - 72 LWB 2 wheel drive truck was ever sold with a one piece shaft. Most (if not all) full sized cars had 2 piece shafts too.
