Old 09-13-2009, 03:51 PM   #1
SERKETSICCS1NINE
SERKETSICCS1NINE's Avatar
Sb 327 question...
This may sound like a stupid question but that never stops me. Will a flexplate for a 350 work on a 327. I was told that the flexplate on the 327 might be balanced differently. Anyhelp would be appreciated. I just bought a rebuilt 700r4 and am trying to get it together.
61 Apache 327 sb from a 63 vette
SERKETSICCS1NINE is offline   Reply With Quote
Old 09-13-2009, 03:53 PM   #2
2tons of fun
Re: Sb 327 question...
internaly balanced motor, flex plate has no bablance on it.
2tons of fun is offline   Reply With Quote
Old 09-13-2009, 03:57 PM   #3
SERKETSICCS1NINE
My 327 is externally balanced.
Old 09-13-2009, 04:16 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
The 327 may show balance marks on the vibration damper, but it's an internally balanced motor requiring a neutral balance flywheel or flexplate.
The 400 small block Chevy requires the external balanced flexplate. A quick catalog check also indicates the 1986-97 sbc with the one piece crank seal is also external balance.
You just need to have the right diameter for the starter/torque converter. They come in two sizes, 153 tooth and 168 tooth. If the flexplate that came with the trans was behind a 1985 or earlier 350 with the 2 piece rear seal, it will also work on the 327. If it was on a 1986 or newer 350 it's externally balanced and the wrong one for the 327.
Old 09-13-2009, 04:33 PM   #5
SERKETSICCS1NINE
Thnx markeb01. Much appreciated...
