09-13-2009, 05:26 PM | #1 |
6-V8 bellhousings the same?
I tried the search but came up empty. is a 6 cyl and a V8 bellhousing the same? can I used a 72 6 banger bellhousing on the back of my V8? thanks
09-13-2009, 05:33 PM | #2 |
Re: 6-V8 bellhousings the same?
Yes same thing for all v8,s and 6,s
I BELIEVE IN JOHN 3:16 |
09-13-2009, 05:44 PM | #3 |
x2
09-13-2009, 07:46 PM | #4 |
Six in a row makes it go...
Be careful. Make sure it has the right diameter hole where the transmission pilots. The ones for the SM465 and the ones for the 3-speeds are different.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
09-13-2009, 07:49 PM | #5 |
I'm dumb, what the SM 465?
09-13-2009, 08:52 PM | #6 |
A heavy duty cast iron 4 speed with a very low 1st gear i always called them granny gear 4speeds
09-13-2009, 08:56 PM | #7 |
SM 465 was found in 68 and newer trucks. If you have a 67 with the SM420, it has the small hole same as the 3 speeds.
09-13-2009, 09:06 PM | #8 |
2nd that..... 67 & older bells will accept a car trans(m-20/21/22 Muncie, or the B-W T-10s). The early bell was 4.683(4 11/16"), the late bell was 5.126 (5 1/8") for the center hole. best of luck. Crazy Al
http://community.webshots.com/user/hotrodhorn |
09-13-2009, 09:26 PM | #9 |
http://community.webshots.com/user/hotrodhorn Last edited by 69 longhorn; 09-13-2009 at 09:27 PM. Reason: didnt need 2 posts.... |
09-14-2009, 01:29 AM | #10 |
My 71 has a 3 speed manuel and its the same size pilot hole as sm465
09-14-2009, 02:20 AM | #11 |
Just Not Low Enough!
my 67 has a 4-spd with the super low 1st....is that normal?
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
09-14-2009, 05:47 AM | #12 | |
Yes - all '67-'72 had "granny" 4-speeds as an option. In '67 it was the SM420 (small center hole), and '68-'72 it was the SM465 (large center hole).
09-14-2009, 05:48 AM | #13 |
After reading the above, I guess I was wrong - it depended on the year. 67-small, 68-72 large. Learn something everyday
09-14-2009, 07:20 AM | #14 |
Watch out for your cornhole !
Not all 67-72 granny 4 speeds were SM465s. Some trucks had NP435s. I have one.
09-14-2009, 07:36 AM | #15 |
09-14-2009, 10:08 AM | #16 |
Before we get way off in left field. The OP asked if a six cylinder bell housing will bolt up to a V8. Yes it will, if he is using the same trans from the 6 cylinder then he won't have to worry about the diameter of the hole.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
09-14-2009, 06:31 PM | #17 |
x2 but I'm not sure if he's inquiring about the entire tranny or just the bell housing. He should probably clarify.
09-14-2009, 09:08 PM | #18 |
thanks for all the replys. I'm going to use a Muncie 4 speed with the 6 cyl bellhousing on the back of my 350
09-14-2009, 10:53 PM | #19 |
09-15-2009, 12:29 AM | #20 |
That depends on the yr.....68 up with a 3 spd has the large hole bell , same as a 4 spd truck crazy Al
