Old 09-13-2009, 07:03 PM   #1
Sicboy
Sicboy's Avatar
Let the rebuild begin...
I've been wanting to rebuild the 327 and saginaw in my '66 since I bought it 3 months ago. Well, since I broke a piston skirt a few weeks back, while racing a GTX mopar, no time better than now. Yesterday, my boys and I spent 5 hours pulling the engine and tranny. There must be a 1/2" of sludge on the bottom, back and sides of the motor. I'll be adding a .262 comp cam, HEI distributor, edelbrock intake manifold (blasted aluminum powder coated), Speedway Truram exhaust manofolds (ceramic coated) and aluminum oilpan & timing cover. I already have aluminum corvette script valve covers. I've decided to go with a satin/semi gloss black engine rather than chevy orange to contrast with the aluminum parts. I'll also be painting the engine bay black, after I blast off the 1/2" of 43 year old sludge on the cross member. Here's a few pics of yesterdays engine pull...
Sicboy is offline   Reply With Quote
Old 09-13-2009, 07:28 PM   #2
jason65
Registerd User
jason65's Avatar
Re: Let the rebuild begin...
Good luck vato.
jason65 is offline   Reply With Quote
Old 09-13-2009, 08:10 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Nothing like spending quality time with your sons. My oldest still reminds me (20+ years later) how much fun(?) he had when he was 14, degreasing and sand blasting the front suspension on my 46 Ford sedan! We spent a lot of time in the garage together, and he grew to be so trustworthy I had him button up the bottom of my engines without double checking his work. We remain close today partly because of all the car projects in his youth.
Old 09-13-2009, 09:56 PM   #4
padresag
the do go in and out easier if you remove the trans and the hood first
ron
padresag is offline   Reply With Quote
Old 09-13-2009, 10:35 PM   #5
198plus
198plus's Avatar
That's what I was thinking.........Anyway good luck with your build, should be a blast having your sons helping you !!!!!!!
ron
198plus is offline   Reply With Quote
Old 09-13-2009, 11:25 PM   #6
Sicboy
Sicboy's Avatar
ron
Actually, it was very easy pulling it out with the tranny still attached. The hood was never an issue. Why remove the hood if it's not in the way?
Old 09-13-2009, 11:52 PM   #7
padresag
whatever
ron
Old 09-14-2009, 12:44 AM   #8
Captainfab
60-66 Nut
The engine compartment doesn't look that bad, but now is a good time to clean it up and paint it up nice. Are you staying with the 3 speed?
Old 09-14-2009, 01:12 PM   #9
MacAttack
283 Drama Queen
MacAttack's Avatar
Wow. If those shots aren't inspirational, what is?
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-14-2009, 01:23 PM   #10
Sicboy
Sicboy's Avatar
Yea, that's in the plans. Gonna power wash & degrease it and then paint the engine bay satin black. Staying with the saginaw 4-speed..it's being rebuilt too. Looked for a muncie or a B&W, but couldn't find one in my price range.
Old 09-15-2009, 12:20 AM   #11
Captainfab
60-66 Nut
Oops sorry for the mistake. Really nothing wrong with a Saginaw 4 speed. Like you say, they're more affordable than a Muncie or a T-10.
Old 09-15-2009, 12:47 AM   #12
Eagar1
Just somethiing to ponder, you can adapt a saginaw 3-speed OD unit onto your 4-speed, to make an 8-speed! here are the schematics, Hot Rod april 75 had a write up on how to do it.
Eagar1 is offline   Reply With Quote
Old 09-15-2009, 01:17 PM   #13
ob1monkey
Make sure you replace the clutch fork clips while you are in there. I didn't and the fork came loose a couple of mionths after rebuild. man what a mess completely demolished the bell housing and the front of the saginaw 4 speed was in peices event he case was shot all in the matter of seconds due to a 5-10 dollar peice I didn't even think about. (the pic with the clutch fork reminded me of it). I know run a 50's bellhousing and a newer clucth fork that has been massaged to fit.
ob1monkey is offline   Reply With Quote
Old 09-15-2009, 11:10 PM   #14
Sicboy
Sicboy's Avatar
Whoa, that sh*t is way over my head.
Old 09-15-2009, 11:12 PM   #15
Sicboy
Sicboy's Avatar
Thanks for the tip, bro. I gotta order a new bell crank pivot ball stud, so I'll order a new clip also.
Old 09-18-2009, 09:22 PM   #16
Sicboy
Sicboy's Avatar
Well it turns out that I didn't break a piston skirt, I spun a rod bearing.
Here's a pic of the first coat of satin black.
Neighborhood white trash...
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Old 09-18-2009, 09:42 PM   #17
rookierodbuilder
rookierodbuilder's Avatar
That engine bay is lookin' pretty snazzy!
rookierodbuilder is offline   Reply With Quote
Old 09-18-2009, 10:50 PM   #18
66GMC-Canuck
66GMC-Canuck's Avatar
Sharp looking engine bay...
66 GMC 1500 Series LWB
66GMC-Canuck is offline   Reply With Quote
Old 09-18-2009, 11:06 PM   #19
likaroc13
Rollin' Old Skool
looking good...what kinda paint did you use?
Old 09-18-2009, 11:19 PM   #20
Sicboy
Sicboy's Avatar
Rustoleum Satin Black. Came highly recommended.
Old 09-19-2009, 12:41 AM   #21
Heater63
Heater63's Avatar
Now thats the way to raise young men!
The time you guys are spending together on this truck is priceless.
BTW, the 327 is awesome...keep it going as long as you can.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 09-19-2009, 12:09 PM   #22
Sicboy
Sicboy's Avatar
It was bright and sunny yesterday. Got a coat of primer on and two coats of satin black. Today, my plan was to spray the third and final coat...but mother nature has other plans. It's fuggin rainin...and the newspaper is soaked. F@CK!!!
Old 09-19-2009, 02:14 PM   #23
Sicboy
Sicboy's Avatar
You know you're a redneck if...
Old 09-19-2009, 02:43 PM   #24
Eagar1
Mother nature was just gettin rid of the dust for you on your final coat!
Old 09-20-2009, 06:16 PM   #25
Sicboy
Sicboy's Avatar
Finished painting the engine bay. Looks brand new again.
