Old 09-14-2009, 10:29 AM   #1
MyMach5
MyMach5's Avatar
Front Drive Line: Better to Rebuild or Replace
My front drive line has about 1/8" of play in the middle joint (the one that allows it to extend with suspension travel...sorry don't know the name of the joint). I'm getting a pretty good vibration in 4x4 and I'm guessing this is the cause. So, I have a couple questions:
1. Is there a significant advantage to replacing the drive line with a new one rather than rebuilding the existing one?
2. I just put a 4" lift on the truck. If I'm going to replace/rebuild the drive line, would it make sense to have it lengthened to match the lift?
Thanks in advance for the help.
MyMach5 is offline   Reply With Quote
Old 09-14-2009, 10:57 AM   #2
Mudder
Mudder's Avatar
Re: Front Drive Line: Better to Rebuild or Replace
Take it to a drive shaft shop and let them rebuild it. They can lengthen it really easy then. Make sure you measure a couple of times to let them know what you need.
Mudder is offline   Reply With Quote
Old 09-14-2009, 11:38 AM   #3
MyMach5
MyMach5's Avatar
Right on. Thanks. I think we have a couple of reputable places here in Portland. I'll give them a call.
Old 09-15-2009, 07:24 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
I would rebuild too. Much cheaper.
With the driveshaft off the truck, measure from the center line of the front u joint cap on the front diff, to the center line of the rear joint at the transfer case. Give them the old shaft with the new measurement and then go home and fix other stuff till its ready.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-15-2009, 01:11 PM   #5
MyMach5
MyMach5's Avatar
How did you know there was other stuff to fix
