Throwing belts
Hey guys,
So when I installed my engine I found out that some of the brackets didn't quite line up right because I went from the Gen1 350 to a VORTEC top end. I had to cut the alternator bracket to get it to fit. Everything looks like it lined up. But whenever I stomp on it it throws the belt. What gives? I know I'm not the only person that has a vortec set up. Is there another bracket that I can buy? I also bought some new chrome pulleys (crank and water pump) but they seem to wobble (out of round). I think I'm going to go back to the old pulleys and just repaint them. But back to the brackets, I also found out that the rear A/C bracket wont work either because the vortec topend. So is there any place to pick up brackets that will work?
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: Throwing belts
I would get a serb belt setup from a salvage yard and bolt it on. Get one from any truck with a Vortec 350 or a 4.3 Astro van or Blazer. It will bolt right on and you wont throw any more belts for sure. Take the A/C lines from the donor vehicle too so you can have hoses put onto those fittings to work for your truck. Good luck.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Re: Throwing belts
I'll have to call around. I don't have A/C right now. The P/O tore it out. But I want to add it back. He had a short so it won't be as easy as I hoped.
Re: Throwing belts
Can you do an electric water pump on the serp belt?
Re: Throwing belts
Maybe with an aftermarket serp belt set-up. Not with the factory stuff that I'm aware of.
