09-14-2009, 01:24 PM | #1 |
Still plays with trucks
worst cap & rotor ever
I think I have the worst looking cap, rotor & ignition coil ever to come off a running vehicle.
That's right these came off a running truck and it seemed to run OK and was smooth. Hard to believe it was running. |
09-14-2009, 01:25 PM | #2 |
Formerly- 1972SuperCheyenne
Re: worst cap & rotor ever
Daaaamn Hard to believe it was running.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-14-2009, 01:29 PM | #3 |
Nothing like arc welding with an HEI ignition coil.
09-14-2009, 01:37 PM | #4 |
I have car A.D.D.
Wow, and I thought mine was bad. You may need to do some heavy adjustments once you get the new ones on. That thing was shot!
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
09-14-2009, 01:59 PM | #5 |
Once I get the other carb on there and can set the mixture screws properly I will see if the ignition needs more work.
The HEI module may be on its last leg too after all the heat that was in that cap. I will pick one up and install it for good measure. It pulls nice to about 4000 rpm but falls flat about there. Once it has closer to the proper jetting we will see how it responds. The stock 170 hp jetting falls way short of what this 330 to 340 hp package needs now. The idle is a little rougher than it should be when cold but part of that is probably because I had to wire the choke wide open as the RPM intake did not have the provisions for the mechanical choke on it. I put an oxygen sensor bung into the headers while I was modifying them so I can use my wide band gauge to jet it properly once I get a functional carburetor on there. |
09-14-2009, 02:00 PM | #6 |
Wow, never seen one that bad before. AS said, I'm surprised that actually still ran in that shape!!!!
09-14-2009, 05:36 PM | #7 |
Looks like the spring/bushing under the coil overheated for some reason. I would get a low resistance bushing if you didn't already.
1977 GMC Sierra Grande |
09-14-2009, 05:47 PM | #8 |
I put an MSD cap & rotor kit on there to replace this burned up one.
It came with both a stock style carbon / copper button and a low resistance all copper button but advised anything with a radio use the copper / carbon style button so that is what I used. It is not completely carbon button like the stocker but a combination that looks like a carbon coating around a copper button. It should be much better performing than stock. |
09-14-2009, 05:55 PM | #9 |
I replaced the coil too so only the module is left in the HEI that could be damaged. I didn't have a spare with the right pin configuration so I ran what was in there.
I will pick up a new one just to be safe. Who knows why that happened for sure. I was thinking that it could have just had the carbon button break and the rest is just the aftermath. The fact that it still ran like this just amazes everybody who sees it and it ran pretty smoothly too, no obvious misses at all. |
09-29-2009, 02:43 PM | #10 |
Thats pretty bad. I had almost the exact same thing happen in my 86 GMC. I thought the trans. was going since it would stutter at hesitate at higher speeds. Then I was getting ready to go and get the owner transfer smog (since I had just bought it), and changed out the cap, rotor, plugs etc. I found mine the same way. I was amazed it ran, and embarrassed I didn't find it earlier!
12-21-2009, 06:02 PM | #11 |
Chevys Kick A$$
Wow holy crap that's crazy to say the least. I can't believe that it would still run when it was that bad. Gotta be about the worst one I have ever seen in my life lol!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
12-21-2009, 06:09 PM | #12 | |
PO had a serious alcohol problem and neglected a lot of routine maintenance on everything he owned in favor of tossing back a 12-pack or more every night. Luckily that was about the worst of it on the truck. He has since sobered up and has made it a year clean & sober and really wishes he hadn't given up his truck.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-21-2009, 10:46 PM | #13 |
78 Big10 454
Man, you win!
