Old 09-14-2009, 03:49 PM   #1
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Will a '73 and up rear end fit into my '72
I hate to ask such an easy question, but I did a search and must not be putting in the right words to find out what I need to know. What I am doing is converting my '72 Blazer to a 2WD. I have planned to switch my rear end to a 5 bolt trailing arm rear end, but I need to know if one from a '73 and up will fit, or what modifications would need to be done to make it work. I know my stuff when it comes to the 4X4 , but this venture into the 2WD world is new to me.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 09-14-2009, 04:19 PM   #2
Primer70
Superbad
Primer70's Avatar
Re: Will a '73 and up rear end fit into my '72
The 73 rear end is wider than the 72 2wd rear end, 1 3/8" wider wheel mounting surface to wheel mounting surface. More than likely not a problem, depending on the offset of the wheels you run.
Primer70 is offline   Reply With Quote
Old 09-14-2009, 04:30 PM   #3
XXL
Seņor Member
XXL's Avatar
You'll need to add trailing arm saddles and plan for a Panhard bar mount somewhere (OEM has a loop cast into the 3rd member but there are plenty of aftermarket options) unless you're going leaf spring.
XXL is offline   Reply With Quote
Old 09-14-2009, 06:27 PM   #4
Primer70
Superbad
Primer70's Avatar
If you go with the trailing arms in the rear I'd watts link it before I'd panhard bar it.
Old 09-14-2009, 10:08 PM   #5
XXL
Seņor Member
XXL's Avatar
Unnecessary complication, IMO.
Old 09-14-2009, 11:30 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Why is that?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
