09-14-2009, 04:42 PM | #1 |
which intake?
i have a 355 with stock rebuilt heads, a mild cam and an edelbrock 500 carb on my 8. my stock intake is leaking vacuum a little bit. i have an edelbrock streetmaster single plane intake in my shopthat i just sandblasted and it looks really good. i figured since it already needs new gaskets i should throw the edelbrock on but people have told me that iit would just make my motor run like s**t since its basically stock. i figured anything is better then stock but i could be wrong. tell me what you think. im not looking to build huge power with it. i was mainly just wondering if it would hurt my performance at all if i went with the edelbrock...?
"I'll keep my guns, money, and freedom. You can keep the "change" |
09-14-2009, 06:30 PM | #2 |
1962 C-10
Re: which intake?
For a street cruiser, you're better off with a dual plane intake. Single planes are designed for high revving, big cammed engines...more for racing. I'd recommend an Edelbrock Performer with a 600cfm carb for you setup. 500 seems a little small for a .030" over 350.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
09-14-2009, 07:51 PM | #4 |
certified tard
Re: which intake?
i tried once and i dont think that there is such a thing as "a good anything" for a 305, except a 530 swap, just my .02
85 swb bbc 5% tint 16.356 @ 84.81 8/07/09 4800 Ft., bad timing, carb tune, and traction, fugg it. 16.169 @ 84.29 8/28/09 good timing, no carb tune, some traction... 06 Equinox LT AWD, wife's and family ride 03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?! 90 Eagle Talon, other project / space taker, GOT head!! 08 Silverado 2500 HD, the bad ass work truck |
09-14-2009, 08:07 PM | #5 |
Re: which intake?
haha, not to dog the BB because I have one, but a buddy of mine had a 305 in his 71 tunnel ram and 2 4's, 4.11s, th400. He was able to cut consistant 13.20s.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
09-14-2009, 08:16 PM | #6 |
Badass
Re: which intake?
oh lol yea a 350 is outa my budget. lol and i would rather have a 383
but you never awnsered my Q? is the rpm going to work well on my 305?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
09-14-2009, 09:11 PM | #7 |
BAD BOW-Silverado XST
Re: which intake?
The RPM is a little too much for a 305. A big carb might work with it. A performer will do better for a street truck.
09-14-2009, 09:19 PM | #9 |
Re: which intake?
gchemist is right the RPM is too much for the 305. I was going to recommend the performer eps #2701.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
09-14-2009, 09:22 PM | #10 |
Badass
Re: which intake?
yea i was thinking that.
what would happen if i put it on? would it run all ****y, but i allready got the rpm for free.
09-14-2009, 09:23 PM | #11 |
Superbad
Re: which intake?
*****in85, the single plane manifold will probably make it run worse than the leaking stock one. If it's just a gasket leaking on your stock manifold I'd just replace the gaskets & call it good if you don't have money for a dual plane manifold.
3r!c84, the 305 is basically a 350 with smaller pistons & crappy flowing heads. The Performer RPM is a great high rise dual plane manifold, but I think I'd go with the regular Performer on the 305. |
09-14-2009, 09:38 PM | #12 |
Re: which intake?
Oh, since you have it bolt it on! You'll have to tune the carb properly. The Qjet will work because it has a vacuum secondaries. You may need to change the vacuum spring. You don't want the vacuum secondaries to open until high RPMs. The small q-jet primaries are an advantage over other carbs with the RPM on a stock engine.
09-14-2009, 09:42 PM | #13 |
Badass
Re: which intake?
ok cool. i dont know how to tune a carb yet.but i do know how to tune that vacuum secondarie spring.
what gaskets and seals do i need? and i need a adapter.
09-14-2009, 09:47 PM | #14 |
Re: which intake?
You can use a vacuum guage to tune it.
http://www.centuryperformance.com/tu...e-spg-148.html http://www.centuryperformance.com/tech-zone-spg-25.html http://www.secondchancegarage.com/public/186.cfm Set your timing first, then use the vacuum to tune it. Use only Felpro gaskets. find a swirl four hole adaptor. The swirl adaptor will help with low end RPMs and torque. |
09-14-2009, 09:50 PM | #15 |
Re: which intake?
i also have an edelbrock 600. would this with the edelbrock single plane make any difference?
09-14-2009, 09:51 PM | #16 |
Badass
Re: which intake?
ok i dont got a timing light or a vacuum guage.
my naber probly has the light. i dont know what head/intake gaskets to buy.i looked on jegs and there are so many lol
