Old 09-14-2009, 06:13 PM   #1
big10ratrod77
big10ratrod77's Avatar
ok boys whats the plan
ok tomarow in auto mecnaics class im gonna be giving my truck a tune up last week i droped in a new set of plugs now its time for cap and rotor and plug wires. so how should i go about this (by the way its a 77 chevy big 10 with HEI). should i change the wires first or the cap. also i want to get a hotter coil on down the road, can i get some sugestions im lookin hotter spark with reasonable price. and any tune up tips are aprecated
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 09-14-2009, 07:01 PM   #2
spaseghost
certified tard
spaseghost's Avatar
Re: ok boys whats the plan
change them all at once. new plugs arent as efficient with old wires, they still have alot of resistance. check napa or autozone for hei upgrade kits, they are fairly cheap and wrok great. mark your wires locations too, set your timing and idle after you install everything.
85 swb bbc 5% tint
16.356 @ 84.81 8/07/09
4800 Ft., bad timing, carb tune, and traction, fugg it.
16.169 @ 84.29 8/28/09
good timing, no carb tune, some traction...
06 Equinox LT AWD, wife's and family ride
03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?!
90 Eagle Talon, other project / space taker, GOT head!!
08 Silverado 2500 HD, the bad ass work truck
spaseghost is offline   Reply With Quote
Old 09-14-2009, 07:26 PM   #3
Chlsnk
Chlsnk's Avatar
Go with the MSD high out put ignition module I put one in my truck and in my el camino it is a noticeable difference in the smoothness in idle.
Amazon.com: MSD Ignition 83645 Digital HEI... Amazon.com: MSD Ignition 83645 Digital HEI... <<<<< thats the one. It also has an ajustable rev limiter so you can have a stop and won't blow your **** up.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 09-14-2009, 08:11 PM   #4
LiveAnimals
LiveAnimals's Avatar
Forget MSD modules, I would reccomend the MSD tune up parts though - cap, rotor kit from O'Rielly/Kragen (screw AutoZone) and some Super Conductor wires.
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 09-15-2009, 07:21 AM   #5
big10ratrod77
ive done bought the cap rotor and wires i was wondering what to change first so the install will go easier.
what is in these kits
Old 09-15-2009, 11:22 AM   #6
TDS-MN
I like to run the new wires one at a time, and loosely set them on the terminals on the old cap, as a first step. And I use a Sharpie to put the cyl number on the end of the wire just as a backup.
Then I remove the new wires, and replace the cap/rotor as needed, and reattach the wires.
I find it rewarding to look in and see all the wires in their holders, not crossed or twisted.
Good luck with the project!
TDS-MN is offline   Reply With Quote
Old 09-15-2009, 07:30 PM   #7
spaseghost
certified tard
spaseghost's Avatar
just an upgraded cap and rotor, sometimes they come with new wires.
85 swb bbc 5% tint
Old 09-16-2009, 09:38 AM   #8
jchav62
1962 C-10
jchav62's Avatar
1-8-4-3-6-5-7-2, that's your firing order. Memorize that...
If you know which one is number one on the cap (usually around the 5 o'clock position on an HEI cap), you can pretty much tear out the old and put in the new. Start from one and work around the cap clockwise. I always start from scratch..
Good luck!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
