Old 09-14-2009, 06:29 PM   #1
brownge
Remove rear cab stainless trim?
I have a 72 Cheyenne Super and it has the stainless trim that runs underneath the rear window and wraps around the rear of the cab and butts up against the drip rails. Does anyone have any tips on removing it without bending it all out of shape? Any special tools required/recommended?
Thanks!
brownge is offline   Reply With Quote
Old 09-14-2009, 06:46 PM   #2
dfwright
dfwright's Avatar
Re: Remove rear cab stainless trim?
subscribing... I haven't taken mine off yet either.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-14-2009, 08:34 PM   #3
rwolf9653
more ideas than money
rwolf9653's Avatar
There is a molding removal tool that you can get which should work on that trim. I left mine on and worked around it because I knew I would jack it up trying to get it off.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-14-2009, 08:38 PM   #4
Mayo
Cool Truck
Mayo's Avatar
I pulled one of at a junk yard. On the bend around the side of the cab, it was kind of dented and wasn't on the clip all the way so I took a screw driver and pryed it a little and just pulled it off with my hands very slowly. It cam off pretty good, but I bet if I ever take another one off I will find out the correct way to do it.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 09-14-2009, 09:05 PM   #5
Woz
I took mine out the easy way I guess... cut it out from the inside. I replaced the rubber. It was a challenge getting it in. I found it was easier to install it prior to placing the window in the cab.
Woz is offline   Reply With Quote
Old 09-14-2009, 09:09 PM   #6
red71c10
The Red Menace
red71c10's Avatar
I think he's talking about the paint separation trim that runs along the back of the cab below the rear window and not the rear window trim that goes inside the window rubber.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 09-15-2009, 09:04 AM   #7
brownge
Yep, it's the thin lower piece of trim, below the rear window.
Old 09-16-2009, 07:47 AM   #8
KEL
72 GMC
KEL's Avatar
this should be close enough
http://67-72chevytrucks.com/vboard/s...d.php?t=333478
KEL is offline   Reply With Quote
rear cab trim stainless
