Junior Member
ol Curt Suffers Setback...I think
I didn't put my passenger side door on during the process. I am a one man shop. My best able bodied assistant (my son) moved to Indy. My two neighbors can do a lot of grunting, but not much lifting.
I have a fairly large gap between the bottom of the door and the front of the rocker. While the front\top of the door is very tight and looks like it should be dropped, I feel I am out of adjustment on the slots that are part of the hinge that fastens to the pillar. Hope somebody can offer advice on an adjustment, but I suspect I am not through with rocker work!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
Re: ol Curt Suffers Setback...I think
Yeah, it looks like more rocker work to me.
The door top's gap looks ok. Also, the height seems to match up nicely on the door's body curves. It looks to me like the rocker is just too low. But, I'm no expert.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" |
Senior Enthusiast
I'm a one man operation as well. What I did to adjust my doors was open the door, place a 2x4 the length of the door, under the inner door bottom, not the outer lip - and support the 2x4 with a floor jack centered under the door.
It might be worth trying that, then loosening the hinge adjusting bolts to see if there is any more adjustment available, without losing control of the door. Be sure to either scribe the existing location, or outline the current fit with masking tape at the hinge so you can see how much it changes. Because these cabs are made up of so many pieces, it's not uncommon to have uneven gaps in different places, or replacement doors that don't fit the same. Rather than focusing only on the surrounding gaps, I also tried to get the best alignment on the body lines, as in the crease at the bottom of the window, and the indentation just above the top of the front fender. |
Junior Member
It moved a little but not enough to make much difference. I thought I might go and adjust the other side a bit so it would close good. One of the new stainless bolts didn't feel quite right. I went to loosen it and it was snug. One more turn and it snapped it off in the A Pillar.
It won't be much longer and this thing will be sold off like many of the others on here. The only difference is this one is in pieces. ![]() I may have to walk away for a few weeks!
1 thing at a time is progress.
Hang in there Bob!! If body work was easy everyone would be doing it. Take a comparitive measurement from the left side of the truck to the right. Sorry if I don't remember, but is your left side done and lined up? With the fender off of the left side take a measurement from a hinge bolt on the pillar down to the top of the rocker and do the same thing on the other side.
From the pics it looks like the rocker is low like you said. They say a picture is worth a 1000 words until it comes to bodywork. ![]() Go take a little break and go back to it when you have cooled off.
Alan
Philippians 2:14-16 |
Junior Member
Thanks Alan,
I think snapping the bolt off in the driver side a pillar was the final straw for awhile. That will be a bi*^* to get out. I had hoped to have the interior bak together and working on body panels by fall, but the cool weather seems to be creeping in. I'm running out of years and patience.
Registerd User
You'll get it Bob.
Resistance is Futile
I use stainless hardware at work all day. The stuff binds like it has superglue on it! I would suggest using anti-sieze when installing stuff.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Just step away, i wanted to sell mine a thousand times!!
#11 | ||
You'll get it. And when your all done you can sit back and read this thread and remember all of the funs times you had.Quote:
![]() If and when I use stainless it will be on the final assymble with antisieze. I know it doesn't help the matter at hand, but still good info for someone.
Alan
1961 crewcab
ok, first get a washer that will fit around a door bolt. weld the washer to what is left of the snapped bolt. then weld a nut to the washer, you should be able to get the bolt out then...
I suggest hanging the fender , and cowl extension panel on that side, that will show you if your door lines are right on, and then you will be able to see how low the rocker is compared to the fender bottom. the doors on my 61 were a real b*tch to line up I spent a few hours on each side, then after I took them off and marked them I had to spend a few hours again to get them in the right spot. I am going to look at some of my old threads, some where along the way I asked for some door frame measurements, when I find them I will post them here for you. Last edited by jonzcustomshop; 09-14-2009 at 11:04 PM. |
#13 |
Senior Enthusiast
I agree, take a breather. I was faced with similar misery a couple weeks ago when I just finished painting my truck, and then spilled an entire quart of paint on the left rear fender and bed. Actually it was more like I threw a quart of paint on it. 1,153 runs and drips. I figured I could throw the spray gun through the windshield, or what I did - go in the house and come back to it 3 days later.
For drilling the bolt, if you dont' already have a set - a transfer punch set from Harbor Freight is only 10 bucks, and will help keep the drill in the center. It's really helpful in not damaging the threads in the post. http://www.harborfreight.com/cpi/cta...temnumber=3577 |
#14 |
1961 crewcab
from these marks you should have 51 inches in both spots.
I noticed that the measurement was about 1/8th of an inch off on the passenger side of my 61 (50 7/8), after much inspecting and remeasuring , the measurement was off by the same amount in both spots on that side, I acertained that the rocker was welded on a little crooked from the factory
#15 | |
Junior Member
Yeah, I have the anti sieze to use, I knew I would be taking the door back off to complete the outer work on it, so I thought I would put it on with the last fitting. I didn't realize they would bind the first time in.
#16 | |
Junior Member
#17 |
283 Drama Queen
![]() Join Date: Dec 2004
^x2 I know the feeling, Bob. If I didn't have a back-up vehicle I'd have gone postal a long time ago, and I've been trying to get mine back on the road since Memorial Day - 08'.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#18 |
1961 crewcab
#19 |
remember that sometimes these rockers aren't perfect either. I know that some guys on the 67-72 side have had to pie cut (then insert a wedge of sheetmetal) the rocker so get it to lign up with the bottom of the door.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 09-15-2009 at 05:49 PM. |
#20 |
Junior Member
I hope there is enough of the bolt exposed to do this. I fear it broke off flush. For drilling the bolt, if you dont' already have a set - a transfer punch set from Harbor Freight is only 10 bucks, and will help keep the drill in the center. It's really helpful in not damaging the threads in the post. I wonder how many drill bits I would go thru trying to drill that stainless?Last time I tried drilling a piece of stainless I smoked two bits.
#21 | |
Alan
#22 |
1961 crewcab
yeah, I didnt realize it was a stainless bolt
![]() the trick withthe washer is to get one with a smaller hole than the bolt, then you can get weld on the bolt , but not the surrounding metal Last edited by jonzcustomshop; 09-15-2009 at 08:20 PM. |
#23 | |
Alan
#24 |
Member of the longbed union.
You know when I was in Iraq the first time in 03, My motor sergeant used to always tell us if we got pissed off at the truck we were working on to just walk away and go talk to another truck or if you could find a tree. You'll get it done we all have problems with our trucks but once they are done it's well worth the pain.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#25 | |
I have those moments all of the time.
Alan
| Bookmarks |
