Old 09-14-2009, 08:23 PM   #1
naynay
1982 5 lug 12 bolt...
So i found a guy with a '82 12 bolt for sale. he says all the spring perches and everything i would need to cut down have already been done. I know that the axle will be 1.5(?)" longer than the 6 lug that's in my 63 c10 now.. is it worth it for me to pick this up for $150?? I am having hell finding one from a '72 here in Dallas. The plans are 100% to have the rear notched and bagged before it hits the road, so is this an ok starting point?
just looking for opinions before i have him haul it all the way up here to me.
TIA,
naynay is offline   Reply With Quote
Old 09-14-2009, 08:33 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 1982 5 lug 12 bolt...
The price doesn't seem unreasonable, what I'd be most concerned about is the fit and alignment of the brackets that are suppose to make it work in your truck.
1. If the pinion angle wasn't set correctly, it may or may not be correctable with angled shims.
2. It would be wise to confirm the mounting pads are in fact the right distance apart for your chassis setup.
3. If the welding was done too quickly or concentrated in one spot for too long, there could easily be warpage in the axle tubes which leads to wheel bearing problems. If the guy that built it is a pro, he'd know this and probably not be a problem. If it's homebuilt...?
Also -
4. What gear ratio is installed. If it isn't what you want, it will cost a couple hundred more to have it changed, unless you can do this yourself.
Old 09-14-2009, 08:44 PM   #3
naynay
right now it is just a bare rear end.. now spring perches or shock mounts or anything.. everything has been cut off... it has 2.73's in it, which albeit low.. i am really building this truck with the intention of taking a cross country trip in it, so highway gears are a plus for me.
I can weld myself but will probably farm that out to one of my coworkers to get the spring perches set just right. the reason i mentioned that i am bagging it is because if i end up 2 or 4 linking it i will be moving the bags further up i the trailing arm so it wouldn't really matter either way...right?
The reason i ask so many questions is because i am in downtown dallas and the truck is about an hour away on the other side of fort worth, so i dont have the luxury of just going out and staring at it t figure it out
Old 09-14-2009, 11:18 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
My misunderstanding. Yep good points, if you're still to design your setup, the only thing that really matters is that the gearset/carrier is in good shape. I'm not familiar with the brakes in this new of a rear end, but the only thing I can think to check is see if the emergency brake cable attachment is something that can be adapted to what's in the 63 chassis.
Old 09-14-2009, 11:42 PM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
That's not a bad Price. Have you checked www.car-parts.com. I've been watching it for awhile and that price is about right on the site. I've found one with 3.42's down by me for $50
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-15-2009, 12:40 AM   #6
Captainfab
60-66 Nut
Just a FYI. If it is in fact from a '82 then it is a 10 bolt and not a 12 bolt. 1980 was the last year for the 12 bolt in trucks. However it doesn't sound like that will be an issue with your intended use. Just thought I'd let you know.
That doesn't sound like a bad price since all the original brackets have been removed. Just as long as it hasn't been butchered.
Old 09-16-2009, 12:22 AM   #7
naynay
thanks man.. he said it's a 12 bolt.. i hope he knows how to count if he's cutting brackets off things
Old 09-16-2009, 12:35 AM   #8
ruffrida2005
what's really the diffrence from a 12 and 10 bolt?
Paul
Old 09-16-2009, 12:39 AM   #9
Captainfab
60-66 Nut
Aside from the number of bolts holding the ring gear onto the carrier (also the number of bolts on the rear cover) the truck 10 bolt ring gear is 8.5" diameter and the 12 bolt's is 8.875" in diameter.
For most applications the 10 bolt is just fine, but the 12 bolt is just a little bit stronger.
Old 09-16-2009, 12:49 AM   #10
ruffrida2005
so on a highway truck it wouldn't matter if it was a 10 bolt.
Paul
Old 09-16-2009, 12:51 AM   #11
Captainfab
60-66 Nut
It's more of a matter of how much power your engine is producing and how much tire you are running. And of course how hard you drive it.
Old 09-16-2009, 12:56 AM   #12
Eagar1
The 12 bolt wil also take more power to push, and is heavier, (less speed and mpg) so unless you are towing or hauling, the 10 bolt is just fine.
Eagar1 is offline   Reply With Quote
