Old 09-14-2009, 09:27 PM   #1
JoeKan
JoeKan's Avatar
De-greasing an engine
My 350 is in need of a good cleaning and painting. I'm not sure what is the best way to get all the oil, grease, dirt and grime off of her. What would you suggest? Powerwasher, carwash, soaping water with a scrub brush? And help will be appreciated.
When I get ready to paint the motor, can I use a brush without the lines showing or is a spray paint can better?
Thanks,
Joe
JoeKan is offline   Reply With Quote
Old 09-14-2009, 09:29 PM   #2
BCOWANWHEELS
Re: De-greasing an engine
OVEN CLEANER AND SELF SERVICE CAR WASH LATE AT NIGHT. MAKE SURE ENGINE IS cold
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-14-2009, 09:42 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Use POR Marine Clean. Then paint with POR 15 engine paint. You can brush it on, it is self leveling, no brush strokes left behind.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-14-2009, 09:44 PM   #4
KMACD71
KMACD71's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=340322 From the detailing section.
KMACD71 is offline   Reply With Quote
Old 09-14-2009, 10:02 PM   #5
big_al_71
big_al_71's Avatar
I used degreaser and the pressure cleaner then re do it again it comes out super clean...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-14-2009, 10:27 PM   #6
'72customdeluxe
I did the engine cleaner setting at the spray wash. My engine was still orange underneath!
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 09-14-2009, 10:29 PM   #7
vectorit
What?
vectorit's Avatar
I'd scrape as much gunk off as you can, then use a pressure wash wand to get the rest.
From there I'd just get a painters bucket, and a gallon of Simple green max. (You can get it at just about any auto parts store).
I use this stuff all the time now, since it doesn't stink and leave a nasty mess.
Plus it doesn't smell too bad on the hands, or your work area after cleaning up.
http://www.simplegreen.com/products_ps_max.php
See about taking off the intake, and all the tin and have it professionally cleaned if you can. Along with the manifolds if you are using them.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-14-2009, 10:32 PM   #8
leddzepp
Moderator
leddzepp's Avatar
I used to use Simple Green all the time (I still use it for a lot of things). But when it comes to de-greasing an engine, POR is 10X better. I was blown away watching the grease just melt off.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-14-2009, 10:35 PM   #9
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Dollar general oven cleaner is what I use. Spray it on, wait about 15 minutes then hose or pressure wash off.
Purple power is also good stuff. I have had good results with that as well.
Jason
jay_shy is offline   Reply With Quote
Old 09-14-2009, 10:48 PM   #10
oldcarfart
Thanks,
Joe
scratch & scrape nasty areas to bare metal, soak with oven cleaner (store brand OK) when crap flows use pressure washer then follow up with greased lightening solvent (Lowes Home Improvement). keep away from paint!
oldcarfart is offline   Reply With Quote
Old 09-15-2009, 10:59 PM   #11
JoeKan
JoeKan's Avatar
Thanks for the help. I hope mine will turn out as good as the one shown on the link.
Old 09-15-2009, 11:26 PM   #12
Soften the grease with a solvent:fuel,engine cleaner,etc,and scrape.i like Brakleen once the bulk is removed.I`d use it from the start but it`ll cost you.It blasts and disolves the crud away.
