aluminum airline
i know that SS is what alot of people run for airline, but could aluminum also be used?
Gearhead
Re: aluminum airline
I asked this same question awhile ago and I believe that the general consesus was that it would work just fine with the proper fittings.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
same with copper line also
Copper is not recommended for automotive applications due to work hardening issues associated with vibration.
It's not a matter of IF it will fail, it is a matter of WHEN. |
i beg to differ copper was used on tractor trailors for the longest time and i have tried it and also works with push style fittings type k is soft and can be bent by hand i do not thing it will crack from vibrations
Seņor Member
You may have had a good experience, but there are metallurgical properties that are very well known by science. Shane has commented, at a high level, on one of the issues with copper. We can go into molecular discussions to prove his statement if you'd like.
On the fast track to nowhere..
Looks like I'll be doing some searching because this def. sounds like something I'd be interested in reading about.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#8 | |
Seņor Member
While the root cause of each type is different, the end results are very similar... there is a significant grain coarsening in the tubing material, which leads to pitting, which leads to pin-holing, and blowout.
