Dana 44 front axle hubs question...
I had to pull apart my hubs to inspect for a noise/vibration on my Dana 44 (from a 76 K5). It took me a few weekends to get it back together since I never had a lot of time... So, now I've forgotten... when you've gotten everything back together in the hub (this is still fulltime 4wd) does the snap ring go in the first or second grove on the axle shaft - the one farthest away or closest to the diff??
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
the pollock
Re: Dana 44 front axle hubs question...
look at lmc's exploded view of your axle..
that's how i find out the answers to these questions.. p.s. bad ass avatar
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
I`ve never messed with full-time,but I`d think it would be the inner groove if it will work.You don`t want much slop because the idea is to keep the axle u-joint centered between the ball joint vertical center.hopefully someone with experience with the full-times will know for sure.I know on what I`ve worked on the snap ring is snug.I usually have to pry on the axle yokes outward to get the groove out to accept the snap ring.
Thanks guys, I've never thought about looking at LMC.
Right now, it is on the outer one and it is not snug, really... I can push the drive flange in further, to the second groove.
huh ???
Hey Tink, LMC doesn't show pics of the hub, but my Haynes manual shows it in the outter groove closest to the dust cap...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Way to go,Chuck!
I guess snug wasn`t the right word.Just not sloppy?It`s not really "prying" either.More like "apply pressure".I always figured this was due to the fresh packed grease in the inner hub and spindle.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-17-2009 at 08:40 AM. |
huh ???
I had to doubble check. My first truck was full time 4x4, but that was 20 years ago. I did like how simple it was with just a spring, a drive flange and a dust cap...
Chuck
#8 | |
It goes on the outer one. There is a spring and a large "cupped" washer that goes in there too. The "washer" goes first, with the cuped part inward. This keeps the spring out of the wheel bearing. The spring is there to keep the axle snug against the back of the spindle. This keeps the axle joint centered in the balljoint's pivot and it keeps the axle seal firmly against the spindle, keeping the mud/water/yuck out of the needle bearing.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
So, just to clarify, the one farthest from the front diff? Thanks!!
#10 | |
![]() Join Date: May 2007
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Farthest from the diff/closest to you.
