Old 09-15-2009, 06:50 PM   #1
Ronm909
67GMC Slammed
Ronm909's Avatar
axle gear question
My step dad has a 70 blazer 4x4 that he is frame off restoring, prior owner made a mess of this truck, we believe the axles may have been swapped, the rear axle perches were welded on badly and rear leaf srings are different sizes, possible accident, anyway, we opened up both differentials and counted pinion and gear teeth and we came up with 2.70 for front and 2.60 for rear, this does not seem right. is my math wrong? both pinions have 16 teeth and front ring has 43 teeth rear ring has 41, any help??? did some one swap these axles or does the front axle have a lower gear by .10.
Ronm909 is offline   Reply With Quote
Old 09-15-2009, 11:34 PM   #2
Ronm909
67GMC Slammed
Ronm909's Avatar
Re: axle gear question
anyone please??
Old 09-16-2009, 12:03 AM   #3
1969K10
1969K10's Avatar
You did the math right. I'd say someone swapped in a different axle for mud runs.
You need to get your gearing closer than they are.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 09-16-2009, 07:28 PM   #4
LONGHAIR
You did the math right...but it doesn't match up to a known combination.
41-16 comes out to 2.56 which is ok....but it must have come from a later model truck, probably from the early 80s.
43-16 equals 2.68, but nothing like that exists AFAIK. It is far more likely that you miscounted something. 41-15= 2.73 which is another available combination. 43-14= 3.07 is another possibility.
You really don't have to physically count them though. The numbers are stamped right into the side of the ring gear itself.
As far as gear spread (difference between frt/rr) it depends upon a few things. The main factors are tire size and available traction. Both put more strain upon the entire drivetrain. I have seen as far as .25 run successfully. It was 5.38 front and 5.13 rear, but this was in a 3/4 ton truck that was used exclusively in mud (as far as in 4x4) rock crawling might be a different story?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
