09-16-2009, 01:55 AM | #1 |
any other fat guys...
have interference with the wheel?
i've got buckets in it now... with a stock wheel.. i'm wanting to put on a smaller 13'' grant i have, but the adapter makes it stick out another 2.5 inches.. I don't have a stock bench to compare but i seriously doubt it'll get me any more room, and my brother even says it's rather tight... and he's pretty normal. Anyone wanna share what they've done? if there is anyone.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
09-16-2009, 02:32 AM | #2 |
BAD BOW-Silverado XST
Re: any other fat guys...
I raised my seat 1.5 inches. The steering wheel is pulled way. I needed the 1.5 inches to fit the 12" thumpers behind the seat. A benefit was that the steering wheel was moved slightly away too.
09-16-2009, 02:40 AM | #3 |
how did you pull it away?
I was looking at physically pushing the column down.. but haven't decided if that's the way to go.
09-16-2009, 06:32 AM | #4 |
i am using a wheel out of a late 80"s cavalier. that gained some room.the next thing may or maynot be safe.i removed the column and fabricated another bracket to weld to the one that holds the column to the dash with about 2.5" differance in lenght on the hole span. then remove the steering shaft from the box and column and compress it about 2.5" inches.the only thing i lost was the switch for the reverse lights was now where the column clamps to the firewall, so i use a toggle switch for them now. you dont lose all the compresion of the steering shaft so some people have told me it is safe , others say it is too risky. use your own judgement
09-16-2009, 07:16 AM | #5 |
Don't Crush em Restore em
I went to and early camero/vega steering wheel that is about 14" in diameter. I have measured other factory wheels, like a SS monte wheel from the 80's and it is about 15", the smaller diameter wheel does give you extra room. The other option is to go to a tilt wheel, that helps to.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
09-16-2009, 08:42 AM | #6 |
Happy to be here
I'm not too big to fit, but I am a full figured guy. If you don't have a tilt column get one. That will make a difference.
09-16-2009, 12:17 PM | #7 |
Project Optimus Prime
if you dont already have it then tilt sterring is tha way 2 go 4 sure
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
09-16-2009, 01:17 PM | #8 |
Parts and more parts
I took my steering column and moved it downward towards the firewall an inch. That meant that I had to change the mounting holes in the steering shaft, but I gained space for the driver. I also use an aluminum steering wheel with the appropriate adapter for mounting.
Frank |
09-16-2009, 01:52 PM | #9 |
Garage wrench
it will for sure!
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
09-16-2009, 03:13 PM | #10 |
I'm a rather large guy and my dually has k5 buckets and I have no problem with the wheel
09-16-2009, 07:21 PM | #11 |
Kid's Mechanic
6' 1" and 285 lbs of pure Love Machine and I agree with the above,. Tilt Wheel is the way to go.No silly adapters and if your looking to keep the stock look its a win win
09-16-2009, 08:37 PM | #12 |
Happy to be here
The tilt column is the way to go for more than just a tight fitting tummy.
The reason I changed mine was because of the angle. With the slightly smaller billet wheel I installed the wheel blocked my view of the gauges, and was just at the wrong angle to be comfortable. By adding the tilt I could adjust to a more comfortable driving angle and be able to see my gauges too. Besides, I wanted my truck to have all the factory options I could put in it.
09-16-2009, 09:42 PM | #13 |
go with the tilt.......i'm thinking about one for my computer desk.(just kiddin) i couldn't help it.it's to serious in here sometimes
" Never look up a dead dogs butt." |
09-16-2009, 11:16 PM | #14 |
My eyes they burn. Why?
Its Kool to be a square 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers New Mexico Member --- Member of the Square Body Club--- |
09-16-2009, 11:21 PM | #15 |
I dont know what's worse... on a computer all day that you need a reaching thing.. or that your so fat that you can't rub one out while sitting on the comp all day
09-16-2009, 11:24 PM | #16 |
I have car A.D.D.
You are the Why would you do that to us? WHY?!?!
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
09-16-2009, 11:30 PM | #17 |
OL BLUU
Wow Boat... looks like you LOST a few pounds while you were in Vegas!
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
09-17-2009, 07:33 AM | #18 |
yeah thanks anthony.....had to get in "thong shape" for the vegas pool scene.the speedo look is out now in vegas.so,you gotta do the thong.
09-17-2009, 08:38 AM | #19 |
Happy to be here
Ya know, I never thought of taking it all off. Heres what I do when I need to cool off.
09-17-2009, 08:50 AM | #20 |
you guys are nuts!
09-17-2009, 09:07 PM | #21 |
