Old 09-16-2009, 02:02 AM   #1
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Going to boneyard to find 9" rearend
Well I'm going to try to find a 9" at the yards soon. I'll be trying to find one that has the following:
True-trac with a 4.11 gear or close.
As close to the width of the 56 truck rearend.
What is the stock width from flange to flange on the 56 rearend?
Which vehicle will most likely have such a rearend?
I've heard of the 1977 Broncos but they be difficult to find.
Tri5
Tri5Nerd is offline   Reply With Quote
Old 09-16-2009, 06:06 AM   #2
Kim57
Kim57's Avatar
Re: Going to boneyard to find 9" rearend
Tri5
This site should help in your hunt. It has the widths of a bunch of rears on it.
Kim
http://www.carnut.com/specs/rear.html
This site has some info on what to look for.
http://www.kevinstang.com/Ninecase.htm
Kim57 is offline   Reply With Quote
Old 09-16-2009, 10:12 AM   #3
Lextech
Lextech's Avatar
Tri5,
I can't answer your original question---But, don't overlook the 8.8 Ford rearends. They come in many ratios, limited slip and disc brake configurations. The Explorer rears (That I have seen) usually have posi, disc brakes and 3.73 or 4.11 gears.
Jeff
Lextech is offline   Reply With Quote
Old 09-16-2009, 11:22 AM   #4
Tri5Nerd
Tri5Nerd's Avatar
Originally Posted by Lextech View Post
Tri5,
Jeff
LexTech,
Good suggestion, I've seen a few guys here use them, how can you tell what ratio they are from the tag?
Kim,
The list with the widths will help me in my quest. I still need to find what's the maximum and minimum widths to use on the TF trucks. Anyone know the answer?
Edit: Just found the width, it is 62" wide, is this flange to flange or backing plate to backing plate?
Tri5
Old 09-16-2009, 11:40 AM   #5
robin58
Pretty decent discussion on the topic here:
http://www.67-72chevytrucks.com/vboa...d.php?t=281266
robin58 is offline   Reply With Quote
Old 09-16-2009, 01:53 PM   #6
Lextech
Lextech's Avatar
There is a tag on the rear cover. Example: 4.10 posi would have a tag that looks like (4 L 10 8.8) 3.73 posi would be (3 L 73 8.8) The "L" stands for Limited Slip. If there is an empty spot where the "L" is in the example then the rear is an Open type---One Legger.
Jeff
Old 09-16-2009, 05:19 PM   #7
hotrodrookie
hotrodrookie's Avatar
I went with the exploder 8.8 in my 59 and it seems to be a good fit. Yes the stock axle truck width is 62" from mounting to mounting flange. If you are looking to have the stock width and chevy lug pattern you can buy 1 inch spacers and be within a quarter inch if Im not wrong. As Jeff said, look for the L on the diff tag. Iv noticed that usually the 4 door explorers come standard with 3.73 locking diffs, other then the open option which seems to be standard in the 2 dr sport tracks. Also look for 95+ as they have disk brakes.
hotrodrookie is offline   Reply With Quote
Old 09-16-2009, 11:36 PM   #8
Tri5Nerd
Tri5Nerd's Avatar
I currently have a narrow 9" with disk brakes but the caliper hits the frame due to notching I did, this is why I want to get a 9", I will reuse the caliper and rotors since they already have the chevy bolt pattern drilled.
I'm also going to try to find one with 4.11 gears if possible.
I'm not going to narrow the search for just one particular vehicle but the 73 - 79 F150 will be high on my list from what I've read and been told.
Old 09-18-2009, 10:46 PM   #9
Tri5Nerd
Tri5Nerd's Avatar
Back from my trip to the boneyard
Here's the best I could to do today while visiting 3 junkyards.
A 9" from a 1986 Bronco 4x4, with the tag discription.
First line: WFE BK2 4D03
Second line: 3L 50 9 S319D
So I'm assuming that this is 3.50 gear Traction loc or POSI with big axle bearings and 31 spline.
I can't tell what the date code is, someone please help with this?
I'll use the disk setup that I have from the other 9" rear end.
The hardest part is lifting this beast.
Tri5
Old 09-19-2009, 01:12 AM   #10
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
This is some good info, I've been thinking about a 9".
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
