Old 01-14-2003, 03:23 PM   #1
CustomMike
Which heads to use
I am building a stock 350 with a mild cam and headers. I have two sets of heads. One set is 3998920 the other is 333882 in the heavywieght casting. Which ones will be better? They both appear to have the same size valves.
CustomMike is offline   Reply With Quote
Old 01-14-2003, 09:16 PM   #2
BobS
BobS's Avatar
I'm not familiar with the 920s but based on past experiences with 882s, I'd go with the 920s, they can't be any worse.
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 01-14-2003, 09:34 PM   #3
neonlarry
neonlarry's Avatar
I would use the 882s, or try to find some better heads. The 882s are supposed to be the best of the common smog heads, but they still aren't great. There are good heads around if you are lucky. I have found a set of ready to use 487x heads, and a set of 291 camel humps that might need some work, both for really cheap. Since you are just building a stock engine though, the 882s would be fine.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-14-2003, 10:57 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Vortec.
Member Nr. 2770
Old 01-14-2003, 11:03 PM   #5
bigjimzlll
bigjimzlll's Avatar
the 882s,if they are the heavy castings are a good head. I dont believe all the flow numbers Ive read on them though..they say they flow as well as vortecs and good fuellies. for a mild build they would be fine.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
