low n' slo
![]() Join Date: Mar 2009
Pricing for a "z"
Third time's a charm!! Can I get a ballpark figure on someone "z'ing" my frame?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Re: Pricing for a "z"
Are there any shops in your area you can check with? Extensive Kustoms?
low n' slo
i could try calling them, but their wait list is always forever and the prices are out of my range!! they do some awesome work though
Give Outlaw Motorsports in Fort Worth a call..They do good work..
PROJECT 7DEUCE
![]() Join Date: Dec 2002
You get what you pay for don't cheap out on frame modifications..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
low n' slo
i dont plan on cheaping out..theres tons of places im sure that do quality work that is cheaper than extensive, well i hope lol. i read on another forum that some guy would do it for like $300. so i wasnt sure if he was kidding, or if its really that much
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 09-16-2009 at 07:12 PM. |
Happy to be here
![]() Join Date: Mar 2000
What might be a more appropriate question is are there any quality shops in your area that can Z your frame.
If your going to Z the front, what are you doing in the rear? Will you need the same shop to build a step notch? I just did a quick search on Google and found the following shops that you might call. Cutten Customs has been around for many years. I don't know anything about Cut Throat Fabrication, but the do show a slammed 68 Burb on their site. http://www.cuttencustoms.com/services.php www.cutthroatcustomsfabrication.com-
#8 | |
It'd be alot cooler if you did
67-72 parts collector,…
![]() Join Date: Nov 2002
Make sure you figure all expenses when pricing a "Z". Not just the frame work.
Think about raising the entire engine/trans combo. (as in new engine mounts and trans mounts/crossmember) Raised sheetmetal work for the tranny tunnel and driveshaft tunnel. Custom carpet to use in your now "non original" floor. Custom/modified trans linkage. The list goes on and on. Not being negative,... just want you to weigh all the costs. I had to forget the "Z" idea,... since I can't weld. That's why I chose the Porterbuilt Dropmember route. It worked out the best for me.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-18-2009 at 10:00 AM. |
![]() Join Date: Oct 2008
Extensive was charging me $1700 for a Z. This was my first choice but then I ran into this site and the dropmember caught my attention because it was $700 less, nice design, and the steering upgrade. I could probably go on with the benfits but in the long run a DM is the best way to go.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
#11 | |
Wow chuck..Didnt even know about their hack-job till now..
Still..Z"ing the frame dosnt compare to a full-frame build..If they screw that up, Then that would REALLY be something to start a good ol' shop bashing thread about... |
#13 |
low n' slo
lolife, i didnt know all that was involved in z'ing a frame. thats A LOT of work, if all my quotes are anything over 500 then i might has well save up for a dropmember..and it looks like i might lol.
#14 |
Keepin it old school
I was quoted 1,900 for a "Z" by The Choppin Block in Fresno. 1,500 to "Z" the frame and 400 to assemble the suspension..
#15 |
most shops will be between 500 and a grand for the basic Z. Its a ***** if the engine and everything is in the truck.
#16 |
anybody have a pic of a Z'd frame?
#17 |
Happy to be here
#18 |
Thnx n2trux
#19 |
DHPmike that was one of the best replies i have read so far, those guys are realy slick by shaving the bottom of the frame to avoid a body drop.
#20 |
Catchy title goes here..
![]() Join Date: Mar 2002
DHPmike. I apologize, but did have to remove the last two posts due to advertising rules. Please PM me if you have any questions.
