09-16-2009, 06:05 PM | #1 |
The oddest Todd around
Resetting Odometer
So...
I've pulled the motor out of my 72 c-10, and am COMPLETELY rebuilding / hot rodding it. With that being said, I think it's time to set the odometer back to zero to better represent how many miles the rebuilt engine now has on it... So... How do I do that?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
09-16-2009, 06:27 PM | #2 |
454 MAKES IT ROAR
Re: Resetting Odometer
Not to sure, but isn't it by attaching the speedo cable to a drill and setting the drill in reverse??
This may be wrong so wait for others to chime in.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
09-16-2009, 06:59 PM | #3 |
member #16
Heres a thread with some info. There was another with pics,but I cant find it.
http://www.67-72chevytrucks.com/vboa...d.php?t=159819
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
09-16-2009, 07:07 PM | #4 |
more ideas than money
This can be done but it takes forever!!! You cant go too fast or you'll tear up the odometer so lets say you do it at 100 mph, with 60k on the odometer it will take you 600 hours. Haven't done it myself but I knew a shady guy that said it wasn't worth his time.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
09-16-2009, 07:21 PM | #5 |
or you can set the drill to foward if its got 90k on it already
1967custom |
09-16-2009, 07:41 PM | #6 |
thats what I was thinking
09-16-2009, 09:58 PM | #7 |
Old School, New Style
I've done it before. If you take the barrel out you will see that there is a plastic retainer and if you remove that you can roll all the numbers to 0 and replace the retainer. Just don't break the retainer. If you dig into it you should see what I'm talking about. Its really not difficult.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
09-16-2009, 10:51 PM | #8 |
Yup I have taken the whole thing appart and just removed them from the shaft an set them to zero real quick. Again be verry careful as you can break parts when totally taking it appart that far. Maybe have a spair one to do it on first.
FYI be careful if you go to clean the numbers as if I remember correct you can wipe off the white paint. But then I could be wrong an that only being on the guages. Been to long since I did this. |
09-17-2009, 12:03 AM | #9 |
That plastic retainer is very brittle and breaks super easy. Ask me how i know !!!!!
I BELIEVE IN JOHN 3:16 |
09-17-2009, 03:14 AM | #10 |
Old member
If you break the retainer get a index card and cut a new one it will last for a very long time as long as it's in the truck.
09-17-2009, 10:00 AM | #11 |
Restoration Virgin!
here's a thread I did awhile back....hope it helps ya!!!...
http://67-72chevytrucks.com/vboard/s...d.php?t=321688
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
09-17-2009, 10:10 AM | #12 |
Why not celebrate that hi-po motor and buy a new speedo?! They come with like 1/10 of a mile on them... and the new ones read to 100,000 miles...
09-17-2009, 06:21 PM | #13 |
It really wasnt that hard at all after reading the step by step, the hardest part was removing the needle without breaking it(good thing I had an old spare).
Here's how mine turned out! |
02-09-2011, 11:22 PM | #14 |
6>8 Plugless........
If anyone is trying to reset theirs, I found this post from 2006 I believe and it really helps get the tumblers where you want them.
If you have the odometer wheel out just hold it in your left hand with fingers holding the first metal tab(left to right) and turn the gear with other hand until you have 9 in the ten thousand place. Then just keep holding the first metal tab and now hold the second metal and turn until you have 99***. Then you do the same for the rest until 99999. Then I just reinstall the wheel and then turn the speedo by hand a few turns until 00000. Hope that helps.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-10-2011, 12:22 AM | #15 | |
The Older Generation
LockDoc
02-10-2011, 01:11 AM | #16 |
Leon, to get mine set in the window correctly I set all the tumblers to 999999. Then I hooked my drill up to the speedometer drive and ran it until they went to 0's and the tenths started on the 1. Then I took my finger and pushed all the tumblers up so they are centered in the viewing window.
02-10-2011, 01:44 AM | #17 |
Why would you want to roll back the odometer?
As we all know, you can't roll it back by driving in reverse...
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
02-10-2011, 12:24 PM | #18 | |
Thanks Ryan. I will try that. LockDoc
02-10-2011, 05:14 PM | #19 |
Mine was broken so I had to fix it.
02-10-2011, 05:15 PM | #20 |
Leon, here is a close up of it when I got it done and reassembled.
04-16-2012, 02:56 PM | #21 |
low n' slo
i know this is a little old, but i was going through mine today and i just wanted to add that post 14 is THE way to do it, easiest by far. but what i noticed is that when you giong from left to right, line each metal tab up with the 5 digit. once your done and you put all the metal tabs back on the housing, all the 0's are facing where the window goes.
i tried it with the 9's, and they read 444444...if this makes any sense
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-05-2014, 12:36 PM | #22 |
Need some help. i took out the odomete, broke the plactic piece that holds the metal abs of course, built a new one, but now the odomere is very stiff to turn. I thought the plastic piece i used was to this so i thined it down, but same issue. and Suggestions>?
02-06-2014, 06:10 PM | #23 |
anyone?
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
02-06-2014, 07:52 PM | #24 |
_
That is one of those things that is hard to diagnose unless you are holding it in your hand... What does it do if you remove the plastic?
02-06-2014, 08:00 PM | #25 |
Moves freely
