09-16-2009, 06:37 PM | #1 |
my brakes?????????
I started off changing my rear brake shoes and I proceeded to bleed brakes, no brakes still, I checked front shoes just fine, so I changed the master cylinder got a nice brake pedal when truck is off drove it and could not stop, as far as I can tell the brake booster seems to work fine no air sounds and not a really stiff pedal.I have visually check for leaks nothing that I can see any help would be greatly appreciated thanks.
09-16-2009, 10:41 PM | #2 | |
Re: my brakes?????????
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-16-2009 at 10:42 PM. |
09-16-2009, 11:04 PM | #3 |
they were going down almost to the floor but it seemed as though none of the shoes were expanding out almost like no friction there.
09-16-2009, 11:33 PM | #4 |
Did you bleed the master cyl independently before installing it, connecting & bleeding the lines?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-16-2009 at 11:34 PM. |
09-16-2009, 11:51 PM | #5 |
It may sound crazy, but did you expand the shoes out to meet the drum after installing the new shoes?
Too many dreams, too little money. |
09-17-2009, 12:20 AM | #6 |
Yes we did bleed the master cylinder, but I will have to check and see if he (my father)adjusted the rear brakes.
