Old 09-16-2009, 09:19 PM   #1
El_Crnicero
El_Crnicero's Avatar
Two Gauge Questions
1.) I have a new oil pressure gauge that came with a new sending unit. It is much bigger than the one that is on the back of the block by the dizzy. I have heard that there is another place to put it near the oil filter. The only place I found on my 71's block didn't look light it would work? There is no existing plug but it seems to have threads there? Also I can't put it on the heads because I am running camel humps and they have no access holes. Here are some pics. Any suggestions?
2.) as per the wiring diagram there are two fuel wires, one that just says fuel gauge and the color is tan, and one is the fuel feed Pink. what are the differences?
Is fuel feed to the sending unit? and Gauge just power?
Thanks for your help.
El_Crnicero is offline   Reply With Quote
Old 09-16-2009, 09:45 PM   #2
Legolas894
Chemist under the hood...
Legolas894's Avatar
Re: Two Gauge Questions
I think the spot behind the distributor is 1/8" NPT. You could put a 1/8" to 1/4" adapter and use the same spot. If you have the idiot light pressure switch (like I did), you could also use a 1/8" nipple to a 1/8" tee. Put the old pressure switch in the tee and then you still use the 1/8 to 1/4 adapter for the new sender.
I just did this a few weeks ago. I used new copper tubing in place of the nylon tubing that came with mine. You might have an electrical sender so it wouldn't matter.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 09-16-2009, 09:49 PM   #3
El_Crnicero
this one is an electic sending unit. no lines. just a wire from the top of the knurl to the back of the gauge. plus the part that threads is like 1/2" npt? Im pretty sure its that big.
Old 09-17-2009, 10:43 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Wow those are some big threads for a oil sending unit. Can't say I have ever seen them that big. Typically they are 1/8" NPT.
NAPA (and others) sell adapters that would allow you to step it up. Might take two to go that large.
Most of these type sender won't fit next to the distributor without putting some 45 or 90* fitting. The port above the oil filter works too but it gives you a reading at the filter output, not at the top end of the engine like the one up by the dist. would.
Good luck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-17-2009, 12:17 PM   #5
Green Machine
Green Machine's Avatar
Some blocks have a 1/8 npt plug into the oil galley right above the timing chain cover, might want to check there.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-17-2009, 12:35 PM   #6
mr48chev
mr48chev's Avatar
Napa or other places sell the adapter/reducer. As Legolas894 said you could also put in a T and run the idiot light if the truck has one.
I'm not sure on the wiring for the sending unit and gage, you will have to consult the instructions there.
Old 09-17-2009, 01:43 PM   #7
fixit-p
fixit-p's Avatar
From the pic it looks like 1/4" npt, when you say it's 1/2" npt are you going by the O.D. because 1/4" npt actualy measures .540" on the major O.D. (diameter of 1/4" pipe)
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 09-17-2009, 02:39 PM   #8
El_Crnicero
So it sounds like it might be alwright to just run some reducers to get it down to size?
Hopefully I can get this done soon, I just put a new audio system, and cam & lifters in it. Im ready to go for a drive....
Old 09-18-2009, 12:40 AM   #9
airdale94
airdale94's Avatar
There is no oil press. port in any head, pressurized oil passes through the push rods. There is no power at the fuel sending unit in the tank just ground. The float increases resistance (ohms) and tells the gauge E or F. Tan is the sending unit wire.
There are complete wiring diagrams in the FAQ section.
airdale94 is offline   Reply With Quote
Old 09-18-2009, 01:26 AM   #10
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
