![]() Join Date: Jan 2009
Motor Mounts!!!!
I put new motor mounts on my truck 10,000 miles ago, and the drivers side is already broken.
Is anybody running polyurethane mounts????? are the Polyurethane mounts any good!!!!! are there any other options that don't require pulling the engine???? has anyone made their own interlocking mounts???? 73+ mounts????? are they better???? how hard to install????
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
Never Ending Projects
Re: Motor Mounts!!!!
'73 and later require you to change the engine towers. Not hard but most likely will require pulling the engine.
As for the Poly ones, I have bought them but haven't gotten the truck that far yet. I used them on my '69 Camaro and they worked great. Most likely the last ones you will ever buy. I believe they are interlocking but keep the stock mounting setup. I have read that some found the bolt that goes thru the tower into the mount is larger and you have to drill the tower hole bigger but I have not confirmed that myself. As for swapping them in, you can do one side at a time, placing a floor jack (with a piece of wood on top) under the oil pan and jack up the engine enough to swap them. Good luck.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
you will have to do some drilling to install 73+ nothing major, but you would be the king of kings if you did it with the motor in.
#4 | |
