Old 09-16-2009, 10:34 PM   #1
slugish
Slugish
how to make room for fatter wheel -tire
Has anyone ever ground down (or rolled or whatever ) the 1/2 in or so inner fender lip to make room for a tire to really fill up the fender well .
If so ,whats the best way . Is this not a good idea . Do not want to mess my truck up either .
slugish is offline   Reply With Quote
Old 09-16-2009, 11:44 PM   #2
CoggedBelt75
CoggedBelt75's Avatar
Re: how to make room for fatter wheel -tire
What year truck and how big of a tire are you planning? I have 31 x 18.50 Hoosier Pro-Street Radials on 15 x 14 Convo-Pros with 4 1/2" backspace under my '75 but the rear end has been narrowed to 44".
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 09-17-2009, 08:21 PM   #3
slugish
Slugish
thanks for responding Joe,
I have a lowered 84 -- top of rear tire about even with bottom of fender well
I have 275x17x50 tires on 17x9.5 rims now , but would like to take it to the max on what would fit
Ihave stock rear & axles .
I've measured the room Ihave left & think I COULD GO ANOTHER 1.5 IN ?
IF THEY RUB , WHAT IS THE BEST WAY TO TRIM THE FENDER FLANGE SO THEY WILL FIT ?
Old 09-17-2009, 08:29 PM   #4
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
There is a tool called a fender roller, you attatch it to the whel studs with your wheel off and slowly & gradually "roll" the lip out of the way. You have to be carefull to take your time so as to not crack the paint. But those are nice tools. Or, I have seen it done many times with a piece of pipe...using the tire as leverage to "roll" the lip. But that is not always as easy.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-17-2009, 08:52 PM   #5
3r!c84
Badass
3r!c84's Avatar
or a baseball bat
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-17-2009, 09:18 PM   #6
slugish
Slugish
Has anyone just tried grinding the lip away , i have a good paint job & do not want to crack the paint . I'm sure would be best to roll if not painted yet.
Old 09-17-2009, 11:18 PM   #7
dv8customs
dv8customs's Avatar
If you grind it you run the risk of burning the paint. You can roll it without cracking the paint as long as you don't try and get it all at once. Helps a bit to gut a few slits as well so you are rolling shorter sections.
dv8customs is offline   Reply With Quote
Old 09-17-2009, 11:57 PM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
if were going for new wheels you can can get 15x12s with 7" or more back spacing were you wouldn't have to narrow the rear end it would require a mini tub and would allow a 29x15-15 tire
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-18-2009, 12:52 AM   #9
Cherub
Cherub's Avatar
Ive heard of guys using a heat gun to heat up the paint before rolling to prevent cracking.
Cherub is offline   Reply With Quote
Old 09-18-2009, 02:51 AM   #10
andrewmp6
A 2x4 and a bottle jack works wonders.
andrewmp6 is offline   Reply With Quote
Old 09-18-2009, 08:51 AM   #11
slugish
Slugish
interesting,
can you tell me how its done > Iguess put the 2x4 against the fender flange & the jack between the board & tire & jack > Is that right??
Also as another post suggests slitting it a couple of times so it wouldnt be as much at one time to bend .
thanks for the advice all of you > Anymore ideas?
Old 09-18-2009, 10:42 AM   #12
Moostifer
a fool with no money
Moostifer's Avatar
don't grind the lip off... it's there to give the panel some strength and rigidity.
most good wheel/tire shops will have a roller.
on my 4x4, I notched it with a cut-off wheel every 3-4 inches, rattle canned it, then gently tapped it with a rubber mallet, then sprayed again
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 09-18-2009, 11:07 AM   #13
Driveway Dreams
I have car A.D.D.
A few relief cuts will help in the rolling of the lip. You can use a heat gun as you roll it but the heat created by the metal moving should be enough on its own. Just GO SLOW...you will be fine.
-Gerald
Old 09-21-2009, 06:12 PM   #14
78maliburat
29x10.5w on 10 in wheel
78maliburat is offline   Reply With Quote
