09-16-2009, 11:40 PM | #1 |
posi rear
Is posibly to know if a rear is posi without taking the cover?
09-16-2009, 11:44 PM | #2 |
Re: posi rear
do a burnout // 2 stripes+posi
09-17-2009, 12:00 AM | #3 |
Re: posi rear
Or jack up one side of rear axle and try to turn it ( with e-brake off , in nutral and front tires scotched.......
I BELIEVE IN JOHN 3:16 |
09-17-2009, 03:40 AM | #4 |
70 Chevrolet=Obsession
Re: posi rear
How about looking at your SPID?
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
09-18-2009, 12:51 AM | #5 |
Re: posi rear
I´m thinking of BCOWANWHEEL idea because I´m goimg to look in a junk yard and trucks are already lifted over rims stack another question is: if I turn the wheels and both turn ahead ? but I was thinking if some rears it comes with a label that can describe if is or is not. apologize for kindergarden question I do.
thanks |
09-18-2009, 01:01 AM | #6 |
Re: posi rear
Non-posi open rear end, if the drive shaft does not turn, and you spin one wheel, the other wheel will turn the opposite direction. Labels, tags, stamping on the housings can be hard to find and read and decode, easiest to do the manual check.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
09-18-2009, 08:28 PM | #7 |
Re: posi rear
An original posi also has a different fill plug in the housing. It uses the square part of a rachet to remove and it is larger in outer diameter to retain the red tag about posi additive.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
09-19-2009, 02:35 AM | #8 |
HaV0KSR559<~~~
Re: posi rear
smokeeeeeeeeeeeeeeeeeeeeeeeeeem
...1969_CUSTOM_1O
FLEETSIDE_LONGBED V8_THREE-FIFTY [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
