Hub and wheel wrong size? How to correct...
I picked up some 20" rims off a newer chevy pickup (mid 90's) but got home and the hub is bigger than the wheel hub opening (about a half inch I figure...so 1/4 inch on each side). Is there any way to correct this? Can I mill the hub? Mill the wheel (don't think thats a good idea)? I have a 67 with power drum brakes and 6 lug bolt pattern...I will have to space the rear, so should be a non issue with that. The front though, if I spaced it, then it woudn't space it out to far I think. Anyone with some advice other than taking back the wheels...
'67 C-10 Shorty - 454, 5spd, and speed holes! |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Re: Hub and wheel wrong size? How to correct...
I haven't done this myself, but seen plenty of talk around here about it. Some have just ground the hub down with a grinder while spinning the hub by hand. It would be quick work on a lathe though, so I'd probably spend a few bucks and go that route.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
I tried searching...do you recall any threads that discuss this?
Well, Whoop-dee-do!
Junior Member
i had put some i think 03-04 factory avalanche alum rims on my 71 blazer. they didnt fit like you are asking about, so had a shop turn the inside of all 4 wheels down to fit over hubs. worked out well, but looked like crap on it.the offset made em stick inboard to far and just didnt look right.
67-72 Truckless for the moment ![]() Member# 1126 The one that got away http://customclassictrucks.com/featu...001/index.html |
![]() Join Date: Jul 2004
Many have been deceived by this one, the bolt pattern is the same, and if you machine the wheel (best plan) then the backspacing is all wrong. Newer axles are longer and the wheels will set in to far and I do not like spacers for safety concerns.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
the few trucks i've seen fitted with the newer style wheels disn't look very good IMO because of the backspacing issue
its all about the +6 inches
looks like a real fat guy on a little tiny bicycle
I agree, but these are aftermarket ones and have the correct offset for my truck (dropped 3/5) if I could just get them on? So now I have heard to machine the wheel or the hub? Which one is best?
i'd do the wheel.
The hub of the truck is designed to carry the load of the truck. You start messing with that, and now the metal is thinner and not up to the task. |
![]() Join Date: Oct 2007
Aluminum is easy to machine the problem will be finding a lathe big enough to turn a 20" wheel. A good machine shop should have one, but it may cost you. Like what was said before, I wouldn't machine the hub.
Well, Whoop-dee-do!
If you don't have to take much off the hub, and it is mainly at the "outer edge", I don't see a problem doing it. The outer bearing race is quite a ways down in from the hub dust cap edge, so it won't effect much. Besides, the outer wheel bearing doesn't carry as much load as the inner (that's how it gets by with a smaller bearing), providing the wheel offset is acceptable. If too much load/ shock is applied to the "outer" end, the bearing &/ or spindle will be the most likely to fail IMO.
If you do the wheel instead, it might be easier to find someone with a Bridgeport mill & rotary table than a big lathe.
#13 |
I would machine the front wheels not the hubs.
