09-17-2009, 01:06 AM | #1 |
3/4T power brake question
I'm upgrading my 69 GMC 3/4T (aka No Buck) with a power brake booster.
So far I have the power brake booster and master cylinder from a 72 3/4T. (Along with the proper brackets, linkage, etc. As of right now I am not changing to front disk brakes, so should I use the 72 power disk/drum proportiong valve or the 69 manual drum/drum prop valve? I'm thinking the drum/drum prop valve. However, it seems the brake lines coming out of the MC are flipped. I can hook up the drum/drum prop valve pretty easily by flipping it upside down, but is this going to cause me any problems? Thanks |
09-17-2009, 04:59 AM | #2 |
Re: 3/4T power brake question
All you want to use is the booster itself, the master cylinder and prop valve are all wrong for drum/drum setups, you will need to reuse your old master and the distribution block (it's not a prop valve on drum/drum). There may be some length issues with the rod that pushes the MC, you will have to double check that else the brakes won't apply or be on all the time.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
09-17-2009, 10:13 AM | #3 |
Yeah, if you use the drum/drum set up, all you'll have to do is THINK about hitting the brakes and the a** end will lock up on you! From what I've heard, using the disc/drum setup will help this. I used an inline proportioning valve. It worked, but the pedal always had a funky feel to it.
09-17-2009, 11:45 AM | #4 | |
Project Junkie! Fishing Poor!!
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-18-2009, 12:52 AM | #5 |
Agree with keeping it the same until you upgrade. But it's the discs that require more fluid. It's the size of the piston. The large rear portion of the reservoir goes to the front discs. The front disc lines are larger also. I think you need some R&R Wes. Last edited by airdale94; 09-18-2009 at 01:02 AM. Reason: add |
