Old 09-17-2009, 01:56 AM   #1
fire120ball
fire120ball's Avatar
Electrical Issues
Okay so about 2 years back I got a 73 Chevy K10 and it had some electrical problems but I always just brushed em off. But they are annoying. Number One, When i turn my blinker on the Gas Gauge moves to the tick, also when I have my brights on my Blinkers are EXTREMELY long and drawn out in between flashes/blinks.3 My interior door lights do not turn on when door is open unless I manually turn them on. couple other dumb ones but can't think of off top of head. Any help would be awesome thanks guys
fire120ball is offline   Reply With Quote
Old 09-17-2009, 08:13 AM   #2
silvereagle07
silvereagle07's Avatar
Re: Electrical Issues
It sounds like you have a ground problem with your lights that are backfeeding through the cluster. Test the ground with and ohm meter on the terminal in the connector for the cluster to ground. The wire color is black and its a 20ga wire at the outermost/bottom of the connector. There is a blue wire above it. The resistance should be .5ohms or less. It goes to a 5/16 sheetmetal screw. The door ajar switches are jammed,stuck or have a poor ground. Hope this helps.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 09-22-2009, 02:33 AM   #3
fire120ball
Thank you sir i will try that
