Old 01-14-2003, 05:49 PM   #1
Alexis
Member since 2000
Alexis's Avatar
trailing arm bushing????
how do you guys take them out......sorry i had to make 2 post but the suspension board isnt going anywhere... any tips. i dont have a torch just hand tools. i've been trying to drill the bushing out but thats gotten knowhere. any help would save my day. thanks.
Alexis is offline   Reply With Quote
Old 01-14-2003, 06:24 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I did not have a torch either so I took a drill and drilled as many holes around the rubber as I could. It was so old and brittle that the drill bit essentially chewed it all out. I grabbed the inner steel with a pair of vice grips and they came right apart. Took 15 minutes for both.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-14-2003, 06:44 PM   #3
COBALT
COBALT's Avatar
You can do that, but as for keeping my trailing arms in good shape without scraping the inside s up I went to the hardware store and got a cheap-o propane torch for $20 including the nozzle. Trust me you'll have OTHER uses for it in the future. They burned out easily (took a couple of minutes each), but it left my trailing arms in good shape. After that I scrubbed the insides with some scotchbrite and some brake cleaner. Good as new.
I wire brushed the trailing arm outsides, and took them to the welding shop to get the cracks patched. Then I soaked them and blasted them with cleaner, and brushed them again before drying them off and painting them.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 01-14-2003, 06:52 PM   #4
1971Stepside
Almost Satisfied
Not to be argumentative, but the drill bit did zero damage to the inside of the bushing. I am very anal about the quality of what I am building and putting into my truck.
The torch would be a good $20 investment.
Old 01-14-2003, 07:00 PM   #5
Alexis
Member since 2000
Alexis's Avatar
haha
i went to get a 12.99 dallor torch......did the job right. i was worried when drilling that i damage the inside. but thanks for the info. ended up spending a few more min. torching a little army guy. lol.
Old 01-14-2003, 07:07 PM   #6
COBALT
COBALT's Avatar
Sweet. I used to torch the "captain" army guy. You know, the one that has binoculars in one hand and waving the troops forward with the other. I always thought it was funny to see the one guy telling everyone else to rush getting blasted. The last to go were the guys that are on one knee with the machine gun on the tripod. I always liked them the most for some reason. Them, and the bazooka guys.
Seattle, WA.
Old 01-14-2003, 07:21 PM   #7
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
The "captain" army guy didnt hold up to firecrackers very well, that is for sure!!!!!!
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 01-14-2003, 07:44 PM   #8
neonlarry
neonlarry's Avatar
I took mine out with a hole saw. That worked pretty well, and it didn't chew up the inside of the whole. Putting the new ones in is way harder. The energy suspension bushings don't come with good instructions, and I ended up putting the bushing in backwards, so now it won't fit and I have to figure out how to get it out. I got the other one in ok, but I decided I didn't feel like working on it anymore today. lol
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-14-2003, 10:22 PM   #9
slam33
slam33's Avatar
All you want to do is burn out the rubber. A hardware store propane torch works best. You don't need or want to heat the arm cherry red. Just burn out the old rubber and push out the guts. Leave the sleeve and get the poly bushings. they go in easy and work great. If you use all the grease they come with, they won't squeek.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
