09-17-2009, 03:27 PM | #1 |
Is my suspension worth saving?
I'm bringing my truck to a shop to have some mods done and they suggested I get a new frame and said my suspension will ride like total crap as it's old school tech.
I didnt know that when It was done origionally so my question is this; should i just scrap or sell this frame and get a new frame for $8500 with new suspension components? I'm not worried about the costs, I just want to know if the origional frame is worth saving or improving with a dropmember or whatever? The fab company http://www.chassisbyaaroniha.net/
Blazer Project Last edited by gottwake; 09-17-2009 at 03:29 PM. |
09-17-2009, 03:43 PM | #2 |
Re: Is my suspension worth saving?
Curious as to what they meant by will "ride like crap". Seems like you should've recieved some more specific responses.
Before I spent the dough, I would get the truck together as is and find out for myslef how "crappy" it is. You will have to pull the truck apart to paint it anyways... you can have the chassis work re-done then if you're not sarisfied. From what I see, the only thing I would be concerned about would be some bumpsteer in the front, which is inevitible with a severely lowered factory suspension. If the work was done on the front end properly... then it shouldn't be too bad. As for the rear, I am a HUGE advocate of the Sleeved bag. Most people have the misconception that it rides "bad".... I use them every chance I get, and I can tell you they ride GREAT.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
09-17-2009, 03:52 PM | #3 |
Hey Nathan,
I was looking for anyone who has experience with this type of set up to give me advice as you did. I was planning on bringing it to a shop and have them install a drop member and powder coating the frame etc... and blasting and undersoating the bottom of the tub-basically a done-deal when i pick it up. But thats when it was brought to my attention that the suspension was crap. I'll forward you the estimate. My origional intensions were to get the motor and tranny mounts installed, channeled, wheel tubs and finisht hte suicide door sheet metal. I was got a price of $21,000 for a new frame, suspension, bags, pumps, fuel cell, lots of metal work...
Blazer Project |
09-17-2009, 04:01 PM | #4 |
I Like Mine With No Shine!
The frame looks good to me. And If you are gonna put a drop member in, it would look even better.
The shop wants to charge you $8500 for a new rolling chassis???? WOW!!! I might would stay far away from that shop. You can pick up a good frame for a few hundred dollars. Bolt on porterbuilt front drop member and a porterbuilt rear kit and still be way under $8500. But like I said, the frame looks fine. And as Nathan said, the only problem I see is maybe the steering setup on the front....that is if it clears fully. The drop member will cure that issue. If you decide to scrap the frame.....please send it my way. Good Luck
Michael 1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day) 2006 GMC Sierra Crew Cab 4x4 1969 Lincoln Continental Coupe Project FOR SALE http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 1981 Honda CM400 C Bobber SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=384152 Last edited by wancosc356; 09-17-2009 at 07:55 PM. |
09-17-2009, 04:13 PM | #5 |
It'd be alot cooler if you did
Your set up will be fine. Someone is trying to take you for a ride.
What makes you guys think there is something wrong with the steering? It looks like he raised it as much as he raised the crossmember; same setup I have and it works fine. Last edited by smashingchuck; 09-17-2009 at 05:28 PM. |
09-17-2009, 05:37 PM | #6 |
It will ride like a truck! J/K It looks good to me. They say when the bags are behind the axle it rides alittle rougher but I can't prove it.
09-17-2009, 05:49 PM | #7 |
Happy to be here
Sounds to me like a good sales pitch. Aaron has hit the big time lately and he certainly deserves props for his creativity. That doesn't necessarily mean that he is correct about your frame.
I think you are on the right track by getting a "second" opinion.
09-18-2009, 10:25 AM | #8 |
09-17-2009, 09:54 PM | #10 |
His work is nice but not worth the money, I used a dropmember and backhalfed the frame and was able to acheive my altitude goals
09-17-2009, 10:24 PM | #11 |
Questionable
You could buy a new frame and every part that Nate sells for it and walk away under $4,000.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-17-2009, 10:37 PM | #12 |
Thanks guys, I am appreciate your comments. I will consider other options.
Blazer Project |
09-18-2009, 12:56 AM | #13 |
VA72C10
I agree...and you're close enough you could send it to him to do the work or to Rockcrln to do the work with PB parts....
Looking for a 67-72 swb or blazer project in or around VA. |
09-18-2009, 07:06 PM | #14 |
If arron is quoting you $8500. then will be getting a tottally one off frame.
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
09-18-2009, 07:20 PM | #15 |
I suppose, Nathan is working on some prices for me. Hows AZ? Just moved from there to sunny (not so damn hot) cal.
Blazer Project |
09-18-2009, 09:47 PM | #16 |
Superbad
Everything looks okay up front, looks like they moved the idler arm & steering box a little forward along with moving them up. If they moved the crossmember forward too it should be just fine. I don't care for the rear bag bracket on the rear end housing, too far away from the axle for my liking. I woulda put the bags closer to the housing & in front of the housing to help relieve some of the load on the link bushings.
09-19-2009, 03:35 PM | #17 |
PROJECT 7DEUCE
Looks like they were wanting some cash from ya....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-19-2009, 05:38 PM | #18 |
WOW thats allot of $$$$ for a good frame, I agree with porterbuilt the sleeve bags ride real nice BOA or behind the axle like its currently mounted. SO get it running a take it for a drive to see how YOU like it.
Adam M STX Designs Motorcycles | Choppers | Hotrods |
09-19-2009, 08:59 PM | #19 |
its looks to me like the guy is doing top notch work.. andi agree that for 8500 dollars you would be getting a complete one off frame.
but your setup looks fine to me as it is, what may be going on is he doesnt want to finish somebody elses work and hes telling you that you need a complete frame because he really wants to get creative and build something badass for you. but hte setup you have now will be just fine
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
