Old 09-17-2009, 03:30 PM   #1
psuautotechstudent
psuautotechstudent's Avatar
Power loss at mid to high rpm
So I bought a 68 chevy with a 250 I6 this summer. I've noticed when I drive under heavy acceleration I get a popping from the exhaust that coincides with power loss. It happens at about 3 or 4 grand (estimate, no tach). I recently cut off the exhaust behind the cab and put a glass pack on. I want to say I could notice it before that, but the exhaust makes it much more noticeable. I have an HEI dizzy on the way and plan on replacing plugs and wires and of course setting the timing. Think that will make a difference? Anything else I should check? Thanks for any Help
1968 C10 250 I6
psuautotechstudent is offline   Reply With Quote
Old 09-17-2009, 04:16 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Power loss at mid to high rpm
I had a problem like that after pressure washing my motor. 350 with points. Tried new points, cap, rotor. Ended up swapping to an HEI, problem solved.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-17-2009, 04:26 PM   #3
mclairmo
Replace fuel filter, too, just to make sure.
mclairmo is offline   Reply With Quote
Old 09-17-2009, 04:47 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Thought of the day "Popping noise under heavy acceleration"
Possible valve float issue. Your springs are not strong wnough to keep the valves seated under heavy work loads. Result is damaged valves and pistons, due to spring failure.
Frank
piecesparts is offline   Reply With Quote
Old 09-17-2009, 04:56 PM   #5
Wrenchbender Ret
The HEI & new plugs will solve any ignition problems. I would pull the valve cover & make sure all the valves are opening about the same height. It could have a lobe wore down on the camshaft.
Wrenchbender Ret is offline   Reply With Quote
Old 09-17-2009, 05:08 PM   #6
Ricks' 72C10
Going Down?
Ricks' 72C10's Avatar
Check your intake manifold for air leaks
I ran one for years and had that problem sometimes
Just another day in Paradise
Rebuild thread
http://67-72chevytrucks.com/vboard/s...d.php?t=354512
Ricks' 72C10 is offline   Reply With Quote
Old 09-17-2009, 05:17 PM   #7
TCLARK
HEI should solve it................Bad coil or coil wire !
TCLARK is offline   Reply With Quote
Old 09-18-2009, 09:51 AM   #8
psuautotechstudent
So it sounds like once I get the HEI in and everything installed we will find out! I'm hoping it will have an effect on my gas mileage too. I'm a college student and can't afford 20 bucks a week. I sure appreciate the help!
1968 C10 250 I6
Old 09-18-2009, 09:58 AM   #9
mclairmo
Skip White sells a cheap HEI on Ebay that most here have had good luck with.
Old 09-18-2009, 11:52 AM   #10
piecesparts
Man, I thought that college taught you guys better than that. #1---If you get the truck to run better, you will drive harder, #2 -- If you drive harder, the gas mileage will go down. #3--- Don't you know that the gas in SE Kansas is different that anywhere else? It takes twice the molecules to make something run down there in Pittsburgh than it does in my area--- LOL. Once you get North of Frontenac it starts to lean out some.
Frank
Old 09-18-2009, 02:21 PM   #11
psuautotechstudent
HAHA! Yeah no kidding! Looks like I'm going to have to find a job to support my gas consumption and my need to buy more parts. And yeah it's something about the air down here in SEK that makes em' run rich. I've heard rumors that it's due to the barometric pressure causes our feet to be a little more heavy, which causes us to push a little too hard on the gas pedal. Hopefully I'll get the job that I'm applying for in Olathe so my truck will lean out a little. LOL
1968 C10 250 I6
