Old 09-17-2009, 03:32 PM   #1
orange prostreet69
muncie 4 speed install question?
I am still currently installing my M22 4 speed in my truck and I am using the original truck 3 speed bellhousing. Should I just use the original bellhousing crossmember and leave the trans hanging like original or should I use an actual crossmember on my new 4 speed trans?
orange prostreet69 is offline   Reply With Quote
Old 09-17-2009, 04:08 PM   #2
psuautotechstudent
psuautotechstudent's Avatar
Re: muncie 4 speed install question?
I'm curious about this one too. i would like to upgrade to a muncie as well in a couple of months.
1968 C10 250 I6
psuautotechstudent is offline   Reply With Quote
Old 09-17-2009, 04:25 PM   #3
I`m not saying what you plan is wrong,it worked for the 3spd.but,I`m using an aluminum car bellhousing and auto crossmember mounting to the tailshaft.That`s how I`ve been doing it.
Old 09-17-2009, 04:46 PM   #4
Green Machine
Green Machine's Avatar
Shouldn't be any problem hanging it like the original trans, just remember that the bottom trans mount holes in the muncie have no threads so you will need to use 2 grade 8 bolts, locks and nuts on the bottom.
Also make sure the bearing retainer on trans matches the hole in the bellhousing. There are 2 different sizes depending on the year of te trans and/or belhousing - 4 11/16 and 5 1/8 they must match, different retainers are available to do the swap.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-17-2009, 04:59 PM   #5
Wrenchbender Ret
With the aluminum trans. I like to put a crossmember under the back of the trans.
Wrenchbender Ret is offline   Reply With Quote
Old 09-17-2009, 05:22 PM   #6
TCLARK
I replaced my 3Speed with a Saginaw 4Speed without any problem !
TCLARK is offline   Reply With Quote
Old 09-17-2009, 08:54 PM   #7
BCOWANWHEELS
I think you,ll need a 67 tk bellhousing because the pilot hole in it is 4 11/16 same as a car. 68 up has 5 1/8" pilot hole
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-18-2009, 12:02 AM   #8
airdale94
airdale94's Avatar
I would get a car bell housing and a truck TH350 crossmember.
airdale94 is offline   Reply With Quote
Old 09-18-2009, 01:36 AM   #9
BCOWANWHEELS
problem with a car bellhsg is thenn you,ll have to fab clutch linkage and x-member
Old 09-18-2009, 06:23 AM   #10
Why is that?Isn`t the clutch still in the same place?You just use an automatic crossmember.
Old 09-18-2009, 09:57 AM   #11
psuautotechstudent
Could you just simply remove the clutch linkage and install a cable to disengage the clutch somehow? I was looking at it the other day for if I get a 350, I'm not sure if the clutch linkage will work anymore (not sure if that's true, but it sure looks like it)
1968 C10 250 I6
Old 09-19-2009, 02:13 AM   #12
airdale94
airdale94's Avatar
Just look up the part #'s for both apps. clutch fork, if they are the same, will work 100%. If different all you would need to do is shorten or lengthen the clutch pushrod.
Actually I know there different (car/truck). There is 2 different GM car. One exits the bell housing mostly parallel and the other is somewhat angled down.
Old 09-19-2009, 04:08 AM   #13
long69
since the transmission will be alum. i don't know if it will be good enough to just hang there like the old 3 speed as it was iron cased? i would go with a cross member also just to make sure. just my 2 cents. but then people say i make no sense.
long69 is offline   Reply With Quote
Old 09-19-2009, 08:31 AM   #14
LONGHAIR
Gearing, gearing, gearing.......I am not a big fan of this swap. These transmissions were designed for high-reving muscle cars. They are lighter and had low rear end gears to take advantage of it, but they are not exactly highway friendly.
2.20-1 first gear is not so great in a pick-up truck.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-19-2009, 09:32 AM   #15
geezer#99
geezer#99's Avatar
Gearing, gearing, gearing. That statement is so true. I changed out the muncie in my 70 chevelle for a saginaw because of the gearing. 3.11 first gear in the saginaw was so much better to drive. Even ran one in my 56 belair with 3.73 rear gears. It's all about gear multipication.
Old 09-19-2009, 09:54 AM   #16
ts71281
I have a M20 muncie in my 70 truck with a 454 - 1st gear is plenty low even if I wanted to pull a boat. It's the M21 and M22 that have too high of a 1st gear. Those are the road racing trannies. At any rate, I've had my muncie installed for 5 years now without and problems I am using a 67 3 speed bell housing and just letting the trans hang off the back of it. My engine has 540 ft lbs of torque and nothing has broken yet or is prematurely worn out. That being said, I don't think it's worth the effort of trying to support the rear end of the trans.
ts71281 is offline   Reply With Quote
Old 09-19-2009, 08:48 PM   #17
airdale94
airdale94's Avatar
A truck TH350 x-member in the stock location in the frame will get you within 1/2" of the tail housing mount. Use a latter model car trans. mount with the stud. Then elong gate the hole in the trans. x-member. Muncie's and B/W T-10's are within 1/2" from bellhousing to trans. mount compared to a TH350.
I wouldn't leave a car 4-speed unsupported in the rear. Especially a aluminum cased one. 3 and 4-speed saginaws are about 100 lbs. Aluminum Muncie's and Super T-10's are at least 125 lbs., and the iron case T-10's are pushing 150 lbs.
Old 09-19-2009, 09:26 PM   #18
ts71281
The Muncie can't weigh anymore than 80 lbs, on the other hand the saginaw 3 speed was a testicle twitcher getting that out by hand. That has to weigh easily 150 lbs or so.
Old 09-19-2009, 09:49 PM   #19
geezer#99
geezer#99's Avatar
I just finished replacing the rear main seal and clutch and did the saginaw bench press this morning on my 67 gmc with 3 gear saginaw. Is indeed fairly heavy. Flat on my back under the truck. Lots of grunting and cursing of coarse. I've done several trannies this way and the 3 gear is lighter than the muncie I pulled several times on my chevelle. Feels like about 75 pounds to me. JMHO
Old 09-19-2009, 10:31 PM   #20
CSGAS
optomistic ah-so
CSGAS's Avatar
Also consider that running dual exhaust without going below frame rails, is MUCH easier with the rear tranny crossmember than it is if you keep the rear engine crossmember in place.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 09-20-2009, 08:33 AM   #21
^That`s one reason why I run the auto crossmember.The factory 3spd 1st gear ratio is taller than any of these 4spds and gets you by just fine,at least in a cruiser.I like how the run with these trans`.I bought a 3spd Blazer with 37s and wanted to swap an M22.I decided against it.It`s a whole different bird.I went with a swap to TH350 and stronger NP205.
