Old 09-17-2009, 08:30 PM   #1
CWS
Bench Bleeding MC with Proportional Valve
I am finishing up the brake upgrade on my 67 C-10, it’s almost time to install my new MC with a proportional valve. (Installed discs on the front, replaced everything on the rear drum brakes, new brake lines/hoses, and the new MC/prop valve is next). When I bench bleed the new MC, do I remove the prop valve from the MC? The directions show just bench bleeding the MC alone, but they appear to be very general directions.
CWS is offline   Reply With Quote
Old 09-17-2009, 08:42 PM   #2
BCOWANWHEELS
Re: Bench Bleeding MC with Proportional Valve
Way i did mine was i put 2-4 psi on m/c and bled all 4 wheels. I never touched the brake pedel.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-17-2009, 09:17 PM   #3
cparman
sharp as a marble
if I were doing your truck, I would bench bleed the master cylinder, as the last thing I did before installing it, and being ready to bleed the brakes. I would then open the rear brake bleeders and gravity bleed the rear brakes and the do the same to the front. Then get a friend to pump the brakes up and bleed again
cparman is offline   Reply With Quote
Old 09-17-2009, 10:42 PM   #4
truckster
truckster's Avatar
Bench bleed the MC without the proportioning valve. Once it's installed you can bleed the entire system.
truckster is offline   Reply With Quote
