rear end question
has anyone swapped a 88&up rear end in to a 73-87 c-10 . if so what do you have to change. rusty
Re: rear end question
guess my question is to stupid for a answer
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
No it's not, but you haven't given it any time to be seen either. There are lots of people on here who have probably done everything imaginable to these trucks. Just give it some time and I assure you someone who has done this swap will speak up. No one wants a bunch off guesses for answers from people who "think" it will bolt right in and have no first hand knowlege. Good luck with your swap.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
rusty.. what is prompting this question? Is something wrong with your axle? Do you have an 88+ axle laying around with better gears???
Also...the board will become more active after people return home from work. Be patient grasshopper.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 09-18-2009 at 05:31 PM. |
#5 | |
Next project: 1970 K10
Should be a very easy swap if you have a welder, or have access to one.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
reason for question my 85 has 2.73's . have 88 rear end has 3.73's , need lower gear for trailer towing.
Good enough reason.... was just curious.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
