Old 09-18-2009, 10:24 AM   #1
Ont67shortbox
Pinion angle
Can someone tell me how to set the pinion angle on a coil spring /trailing arm truck. Is there spacer kits you can buy ,like for a leaf sprung truck, to adjust it ? right now mine is almost straight,should it not be pointing down 3-5 degrees?Thanks for your help
Ont67shortbox is offline   Reply With Quote
Old 09-18-2009, 09:18 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Pinion angle
Is it lowered? If so how, and how much? This info will help get a more accurate answer.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-18-2009, 09:39 PM   #3
Ont67shortbox
Re: Pinion angle
sorry I forgot to add that.It has 2 1/2 inch drop spindles in front,2 inch drop springs,and Nitro drop shocks,The back is a 6 inch drop spring with Nitro drop shocks and ECE adjustable super panhard bar,as well as shock relocators.So 4 1/2 front/ 6 back and pinion seems to be almost straight.Thanks for the help, Brian
Old 09-19-2009, 12:39 AM   #4
westofb
I really hate wet sanding!
westofb's Avatar
Re: Pinion angle
I could be wrong...I am sure someone will point out my mistake if I am....but you could flip the trailing arm mounts over, thus raising the front of your trailing arms and helping your pinion angle problem. Just an idea that may help you out.
westofb is offline   Reply With Quote
