![]() Join Date: Sep 2007
New Ken Harrison Radio - But how?
Okay, so I'm an intelligence analyst in the Marine Corps. My job is to hunt down the "bad guys", yet I can't figure out how to install a darn radio?!?! Need some help from you experts!
I bought a Ken Harrison radio so I didn't have to cut the dash. The truck didn't come with a radio so I don't see any loose wires behind the slots. The wriring harness was re-wrapped by the shop so I'm not sure where to go from here. Do I cut and splice the harness and connect from the harness that came with the radio?? Like I said, I'm a Marine, so lots of colors and pictures helps the most!! Thanks a ton for the help!!! |
>130dB Moderator
Re: New Ken Harrison Radio - But how?
I don't know of-hand what year your truck is, but I have posted a couple wiring harness color guids at the top of this forum. Check those out and get back to me.
If you really need to I can figure out how to splice into the harness properly.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
I saw those, those are awesome! However, I have a '67...
>130dB Moderator
There is part of an existing harness right? or do we need to start fresh?
the pollock
make a new harness, find a switched 12v, find a constant 12v
make a ground point, and then buy a spool of speaker wire and run it to where you want your speakers at.. fresh install no factory harness "in the way" you can make it/ run it how ever you want it.. suuuper simple..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
#7 | |
the pollock
therea re simple online car audio install guides available like these
http://www.wikihow.com/Install-a-Car-Stereo this book has alot of good information in it for you, it covers basic stereo installation also.. http://www.tracyamartin.com/WebPages/Autobook1.html
the pollock
http://www.buy.com/prod/automotive-w...208502720.html
http://www.keenzo.com/showproduct.as...855&ID=2316530
| Bookmarks |
