Old 09-18-2009, 02:51 PM   #1
C10Sim
C10Sim's Avatar
heater return?
Where on the radiator is the heater return located?
Do you need a heater return for a vintage or old air underdash system?
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
Old 09-18-2009, 03:04 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: heater return?
it's not they should be in your water pump and intake
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-18-2009, 03:13 PM   #3
kwmech
Re: heater return?
Return goes into the water pump above the lower hose. Water to the core comes out from the hole under the right side of the t-stat in the intake
Old 09-18-2009, 04:03 PM   #4
C10Sim
C10Sim's Avatar
Re: heater return?
Im a little confused, but the reason I ask was because I purchased a radiator and they ask if I wanted a heater connection?
1968 Chevy Pickup
Old 09-18-2009, 05:10 PM   #5
john
member #16
john's Avatar
Re: heater return?
Some year models returned to the radiator rather than the water pump. Order whichever you have now.
john is offline   Reply With Quote
Old 09-18-2009, 10:50 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: heater return?
pretty sure A/C trucks returned to the rad... in all reality, it doesn't matter, one or the other.
Old 09-19-2009, 12:06 AM   #7
highperf4x4
Re: heater return?
I would recommend getting the radiator with the return connection. You can always cap it if you don't need but if you decide to convert, it's there.
highperf4x4 is offline   Reply With Quote
