Old 09-18-2009, 07:25 PM   #1
americanmusc1e
americanmusc1e's Avatar
Will this Work, or am I crazy!!!!
I busted my old motor mount and instead of buying $80 worth of polyurethane...........................................................
weld the nut to the plate:
somethin' like this????
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 09-18-2009, 08:01 PM   #2
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
Re: Will this Work, or am I crazy!!!!
Really? Rubber mounts are really cheap, You still may get some vibration doing what's pictured. If you don't want to foot the bill for poly, at least stick with original. Just my .02.
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 09-18-2009, 08:02 PM   #3
big mike71
big mike71's Avatar
As much as it hurts break down and spend the bread.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 09-18-2009, 08:18 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
X3
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-18-2009, 08:30 PM   #5
americanmusc1e
My design is that bad huh!!!!
-- Josh
Old 09-18-2009, 08:30 PM   #6
71tahoe
71tahoe's Avatar
Not advocating but I think you need to try it and tell us. Here's some things I notice that could cause problems.
1. Make sure the insulator on topside is the same thickness as the old mount.
2. Make sure to use a locknut. Not a spin locknut but one that is dimpled.
3. You might have to enlarge the hole in the tower and put the bolt through a rubber hose too.
4. Get a safety cable to contain the torque if/when it may or may not let go.
Not a complete list of "what might go wrong" by any means.
Now for a recommendation - go to autozone and spend about $8 for the one designed for that. Then you'll have a backup in case you try it and fail miserably.
71tahoe is offline   Reply With Quote
Old 09-18-2009, 09:31 PM   #7
lowriden58
lowriden58's Avatar
$7.99 each from NAPA online.. spend the $$ and do it right
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 09-18-2009, 10:36 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if/ when it fails, it'll happen when you stab the throttle from a stand still. The engine will lean over, and lock the throttle in that position, possibly even causing more throttle.
Just buy some motor mounts.
Old 09-18-2009, 10:55 PM   #9
powell72
powell72's Avatar
A for effort, and not so good on the result, go get some new mounts and let the cob webs out of your wallet!
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-18-2009, 11:49 PM   #10
mclairmo
I assume he's not serious about running those homemade disasters waiting to happen.
mclairmo is offline   Reply With Quote
Old 09-18-2009, 11:53 PM   #11
highperf4x4
Yeah get the cheap mounts if you have to because it's a little risky. I even snapped an iron exhaust maninfold in half once!
You've got steel headers so you're even more likely to damage them.
I'm gonna second that.
highperf4x4 is offline   Reply With Quote
Old 09-19-2009, 10:59 AM   #12
americanmusc1e
My Idea wasn't to be cheap, I wanted an interlocking mount that was tougher than the rubber ones. If I thought the cheap rubber mounts would last, I would put them on there. The ones I have on there now, I put on less than a year ago!!!!! I guess I'll break down and buy the polyurethane.........
-- Josh
Old 09-19-2009, 11:16 AM   #13
cdowns
cdowns's Avatar
use stock mounts and add a torque strap too
Old 09-19-2009, 03:18 PM   #14
highperf4x4
Yeah after I broke the iron exhaust manifold, I added a chain that I bolted from the frame to the first exhaust manifold bolt as a back up
Old 09-19-2009, 09:46 PM   #15
big mike71
big mike71's Avatar
you say stuff like this and wonder why people crack on you.
Old 09-19-2009, 09:57 PM   #16
highperf4x4
Yeah I was thinking the same thing myself.
Old 09-20-2009, 12:53 AM   #17
haminator
haminator's Avatar
I saw a cable from the drivers side manifold to the frame on a 70 once, it looked factory. Maybe a recall/waranty fix.
haminator is offline   Reply With Quote
Old 09-20-2009, 01:14 AM   #18
jbristo67
resident oilfield trash
jbristo67's Avatar
Dude you can get a set at auto zone for 30
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 09-20-2009, 05:55 AM   #19
mclairmo
t.o.
Old 09-20-2009, 09:51 AM   #20
Longhorn Man
Yes, that is a recall thing.
Old 09-20-2009, 12:41 PM   #21
big mike71
big mike71's Avatar
t.o.
What does Terrel Owens have to do with this.
Old 09-21-2009, 02:32 AM   #22
mclairmo
LOL. That's a good one.
Old 09-21-2009, 08:24 AM   #23
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Has to be one of those "inside jokes"
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 09-21-2009, 07:47 PM   #24
big mike71
big mike71's Avatar
I didn't know what T.O. meant, so I assumed it meant Terrel Owens.
Old 09-21-2009, 11:58 PM   #25
highperf4x4
I was thinking the same thing myself......
I may not have an original thought today!
