09-18-2009, 10:26 PM | #1 |
Got big-block?
some build pics of the GMC K25
Started about a year and a half ago. Bought it as an unfinished project for a bodyshop I call on. Already had a 454/700r swapped in...that had to go and a 468/4L80e put in it's place. Here's a few pics of the progress:
Pic 1 is as bought Pic 2 is of the 1990 454 that was in it Pic 3 is of the 454/700r pulled
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
09-18-2009, 10:28 PM | #2 |
Got big-block?
Re: some build pics of the GMC K25
Got the cab and bed off the frame. Installed the front engine crossmember. Cleaned and painted frame.
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 Last edited by superchevy; 09-18-2009 at 10:29 PM. |
09-18-2009, 10:31 PM | #3 |
Got big-block?
pics
09-18-2009, 10:35 PM | #4 |
Got big-block?
Mounted the gas tank in the rear and cut out a small pocket in the rear of the bed to put in a stainless boat fill.
09-18-2009, 10:42 PM | #5 |
Got big-block?
Rebuilt the front and rear axles and suspension...warn hubs...tough country 4" front suspension lift...ORD rear shackle flip kit for 4" lift...2" body lift...custom rear sway bar...
09-18-2009, 10:45 PM | #6 |
Got big-block?
rear susp
09-18-2009, 10:47 PM | #7 |
Got big-block?
Got the drivetrain mocked up, built and installed...468/4L80e/np205...all fresh and completely rebuilt
09-18-2009, 10:51 PM | #8 |
Got big-block?
pics
09-18-2009, 11:10 PM | #9 |
Got big-block?
Just last week got all the shhetmetal finished and cut in...now to hang the doors, frontclip and get it finish painted...then all the little things to hook up...
09-18-2009, 11:15 PM | #10 |
Awesome!
You gonna share what customizations it took to get them chevelle manifolds in there? Last edited by highperf4x4; 09-18-2009 at 11:17 PM. |
09-18-2009, 11:28 PM | #11 |
Got big-block?
Lol...had to cut and box the frame.
09-19-2009, 12:15 AM | #12 |
SEE!!!!! That's the kind of info you have to share!
Are you SURE you got that fram stiffened up enough? It is a 4x4. Are you gonna punish it? Last edited by highperf4x4; 09-19-2009 at 12:16 AM. |
09-19-2009, 05:38 AM | #13 |
If I may answer for Superchevy,"no" .i think i recall when you bought this your intentions were for a tow/hauler.that pretty black paint,Heavier o/d,and swap bar seem to point in that direction.BTW...NICE!!!!
Now,the secret I want you to share is how you`re handling the speedo drive?Are you going with an electronic to mechanical converter or an electronic speedo?Was the trans from a 6.2 diesel with stand alone ECM,did you have to buy an aftermarket`puter,or go manual kit?Here`s a little coinky dink,I have a`72 K2500 and a 4L80E I`d like to use in it.Don`t worry,I won`t paint it black.
09-19-2009, 09:20 AM | #14 |
Got big-block?
special-K is right...I built it to tow my trailers and cruise around in. As for the 4l80, it's out of a 96' dually...I bought the TCI stand alone computer/harness to control it. I used a T400/np205 adapter...had to have it turned down by a local machine shop to mate to the 4L80...had to change the output shaft as well...
09-19-2009, 11:43 AM | #15 |
Got big-block?
special-k, back when I was researching the 4L80 swap details, I ran across a couple of posts (can't remember where) that the 4L80 has a speed sensor port in the case....if I remember right...it might have two...maybe it was only some 4L80's...anyway...when I got the TCI harness...the instructions showed how to plug everything in, and the location for the speed sensor. I got the TCI tps harness as well to mount to the quadrajet base plate.
I can't remember if I could use the transfer case speedo outlet or not...I'll have to dig out all the freakin' info/manuals when I get ready to dial everything in...I'm sure there's something else I need to buy, lol. There's a lot to figure out on this swap, and it is very expensive...I have more in the trans/rebuild/converter/computer than I paid for the truck originally...a lot more...if I had to do it again, I would seriously consider a T400/gearvendors o/d set-up SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 Last edited by superchevy; 09-19-2009 at 11:47 AM. |
09-22-2009, 11:08 PM | #16 |
Chevy Enthusiast
Looks like its gunna be a cool truck man! Maybe i'll see it some day, your not very far from me.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
01-13-2011, 06:07 AM | #17 |
i know this thread is a little old but as for the rear shackle mount you have, how much lift did that gain you. also any pics of the finished product?
01-13-2011, 10:00 AM | #18 |
Got big-block?
That's a 4" rear shackle flip from ORD.
I'm finishing up final assembly of the truck right now. Need to update my build thread...you can find it in my sig. Casey
