Old 09-18-2009, 11:55 PM   #1
72truckster
Why is my bed sitting on my new gas tank?
I put in my new blazer thank under the bed. Then I put the box back on and the cross rail is sitting right on the tank. More troubling is that it needs to slide forward about 3in, which would make the cross rail right over the filler. It is a long box, steel floor gmc box obviosly going on a lwb 71 chev. The solution I came up with is to notch out the cross sill.
Thanks for any advice.
72truckster is offline   Reply With Quote
Old 09-18-2009, 11:58 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Why is my bed sitting on my new gas tank?
Can you move the tank forward or backward a couple inches?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-19-2009, 12:03 AM   #3
QKENUF4U
QKENUF4U's Avatar
just like everyone else that runs a blazer tank.. gotta notch the rail...
QKENUF4U is offline   Reply With Quote
Old 09-19-2009, 12:09 AM   #4
71swb4x4
71swb4x4's Avatar
The other option is to buy a factory blazer tank fill tube. It's curved to go around the cross rail.
Old 09-19-2009, 12:13 AM   #5
hemihead
hemihead's Avatar
I have a wood bed and just relocated my cross sill back.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 09-19-2009, 12:14 AM   #6
BIGMAC68
BIGMAC68's Avatar
Unfortunately most people find this out after buying a blazer tank upgrade for the trucks. My 70 Chevy short wide has the same problem. Most people will notch the bottom of the cross sill for clearance. I plan on selling mine and going for one of the aluminum or stainless tanks being made by some of the board members. It's a shame the vendors selling these tanks don't tell you about this.
BIGMAC68 is offline   Reply With Quote
Old 09-19-2009, 12:27 AM   #7
72truckster
Thanks for confirming that I need to cut it out. I don't know how I missed this step in my install research, because I read quite a few articles on the install and no one mentioned that it needs to be notched. The custom tanks are nice, and can see why people use them instead. So thanks for the good info and I will get out the cutting tools.
Old 09-19-2009, 01:43 PM   #8
70Custom10Nut
70Custom10Nut's Avatar
Great info. When you say notch the support, is it all the way across the top of the tank or just to clear the filler? I'm looking at doing this soon and will be forever grateful that this was said before I attempted the conversion. I have a wood bed BTW. Cnut
70Custom10Nut is offline   Reply With Quote
