Old 09-19-2009, 01:01 AM   #1
kenm78
Broken Down
kenm78's Avatar
Heater Core Testing.
Just got a 80 Custom Deluxe C10 (Big Ten Model) pickup. I did notice the heater core hoses were cut leaving the heater core isolated. Not sure if it is leaking or bad etc. Any Ideas of how to test it without hooking it back up to the engine? I was thinking about hooking a garden hose up and just letting it circulate for a while and let the water run into the yard??? My only concern is it will be cold water, and without any heat any breaks, or cracks will not open and show a faulty heater core.. What are your thoughts and or recommendations?? Any testing cheats would be great.
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 09-19-2009, 07:00 AM   #2
Prong
Re: Heater Core Testing.
Chances are good it's shot if it's been disconnected. Personally, I'd just spend $30 on a new one and then you'll know what you've got.
Prong is offline   Reply With Quote
Old 09-23-2009, 05:15 PM   #3
kenm78
Broken Down
kenm78's Avatar
Well I decided to test the heater core that is in the truck. I hooked up the heater hoses using a 1/2 inline water valve from a local hardware store ended up spending about 18 bucks on the components. I hooked everything up opened the valves and wouldn't you know it...... NO LEAKS!!!! Sun shines on a dogs A$$ on occasions. Been running it for 2 days now with no internal or external leaks..
kenm78
1982 Chevy 4X4
Project truck
Old 09-24-2009, 12:59 AM   #4
karl
karl's Avatar
Just pray it holds up. I never run tap water in my truck. Always distiled and antifreeze. My heater cores and radiators last forever. I flush and fill every year or so.
karl is offline   Reply With Quote
Old 09-24-2009, 05:51 AM   #5
kenm78
Broken Down
kenm78's Avatar
I'm not running tap water. I am using premix 50/50 antifreeze. I installed water shut off valves so if an when there is a problem the the heater core I can isolate it faster. Hopefully it lasts we shall see though.....
kenm78
1982 Chevy 4X4
Project truck
