Old 09-19-2009, 11:57 AM   #1
Silence86
Silence86's Avatar
break light on dash
ok so this morning i was driving around an i went to apply the breaks, and noticed when i pushed them down. the break light on my dash came on. its an 86. whats this mean?
Silence86 is offline   Reply With Quote
Old 09-19-2009, 12:00 PM   #2
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: break light on dash
Check your fluid level. It may be low, which could be triggering the light.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-19-2009, 12:27 PM   #3
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Silence, same thing happened to me this week. Fluid was low in the master cylinder.
78 Big10 454 is offline   Reply With Quote
Old 09-19-2009, 12:36 PM   #4
Silence86
Silence86's Avatar
is there a switch that is down there for that? i think it may be getting stuck
Old 09-19-2009, 01:09 PM   #5
nlped
nlped's Avatar
Yeah, there's a sensor that "kicks" if the fluid level gets to low. It's right at the master cylinder.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-19-2009, 01:56 PM   #6
menace121978
menace121978's Avatar
my sensor is at the prop. valve located behind the core support attaced to the cross member. just follow the lines from the master down and you will also see a electrical plug bolted to the frame.
i love these 2 pics.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-19-2009, 03:02 PM   #7
Driveway Dreams
I have car A.D.D.
I feel like you used those pics to answer a question I had just last week or so.
-Gerald
Old 09-19-2009, 03:29 PM   #8
trenchwarfare
you want to break your brake light?
____________________________________
trenchwarfare is offline   Reply With Quote
Old 09-20-2009, 12:30 AM   #9
menace121978
yea, good eye buddy... it felt kind of wierd since i think i have posted those pics 4 or 5 times now just in the last month. a bit monotonous!
"Dennis the Menace"
Old 09-20-2009, 10:48 AM   #10
68 TT
Still plays with trucks
68 TT's Avatar
When mine came on the master cylinder was sucking air and failed shortly there after.
If your fluid level is low check for any leaks at the back of the master and in other areas with rubber hoses.
68 TT is offline   Reply With Quote
Old 09-20-2009, 03:27 PM   #11
LONGHAIR
The light can come on for 2 reasons.
An imbalance of fliud pressure at the proportioning valve....which is usually from a leak.
It can also come on because the E-brake pedal has been moved. I have seen this happen a lot. Someone kicks the pedal getting in/out....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
